It's a cooling fan. dos not a pc
  • 7,627 Answers
Can you be more clear? I don't understand what your problem is?
Posted on Jan 08, 2013
AC and Cooling Fans Not Working
Try installing a jumper across the N/O terminal at the relay socket. Temp sensor in the radiator or in the thermostat housing supplies the signal for the relay the other relay signal is supplied by A/C in on position. both fans will run continuous with A/C on. One fan runs intermittent relative to water temp. Be careful not to blow a head gasket. If you leave the jumpers in place, the fans will stop when the ignition is turned off, save the engine until you isolate the relay signal problem. then simply remove jumpers and reinstall the relays
Feb 28, 2017 | 1989 Toyota Camry
Ck engine light problem on 2001 Impala
Well the code is for the circuit - the computer commands the relay to turn the fan on and it doesn't happen.
The computer provides the ground for the relay.
If you have replaced the relay and the fan and the fuse still blows, I would look for a problem in the harness between the fuse box and the fan, including the ground circuit for the fan.
The fuse for the cooling fan is usually a 30amp marked "cooling fan" in the fuse box in the engine compartment.
Do you know what the 25amp fuse that is blowing is for ?
Jul 30, 2012 | Chevrolet Cars & Trucks
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
Freezer fridge Q not cooling fridge
Fan problem, if provisional compartment is warm & freezer works fine then it's the pc fan & visa versa.
Jan 10, 2012 | Fisher and Paykel Refrigerators
My wife has an Advent 7084 laptop pc. Within the last few days the fan has started to switch itself on/off regularly when in use. I presume the laptop is overheating due to the fan being full of dust ? I...
i don't think there's anything wrong there...all laptop fans switch themselves on and off depending on the situation. the fans are normally off but when the temperature rises they turn on to cool off the laptops.
Jun 15, 2011 | Computers & Internet
Iam using HP Desktop D530 when i open some programmes but processor fan runs so fast and loud 2 gb ram in my pc and hard disk is 20 gb how can i reduce noice of fan ?
To reduce the fan noise, open the PC Case and clean the fan. Also, proper ventilation keeps the system cool and the fan runs at lower speed.
Hope this helps!
CreativeTECH
Dec 11, 2010 | HP Compaq d530 Small Form Factor PC...
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
My old Sharp Actius UM32W laptop powers off after about 3 minutes and the number pad "N" indicator light flashes. How do I fix this?
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 19, 2010 | Sharp Actius UM32W Notebook
I have a Protechnic MAGIC CPU Fan, MGT7012UR-015 , 12v, 0.58A in my Acer PC. The manufacture date is 2007/8/28. It has started making a whining sound so I need a replacement. True to form, the warranty...
its a standard 80mm fan. You dont need one by that company as its a interchangeable part.
any of these will work
http://www.frozencpu.com/cat/l3/g36/c15/s58/gallery/p1/Fans-12_Volt_Fans-80mm_x_25mm_Fans-Page1.html
any of these will too
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=+40000573&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=-1&description=80+mm+fan&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Feb 19, 2010 | Magic Protechnic 80mm Sleeve Bearing Case...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
