Question about Toshiba Satellite A205-S5809 Notebook
Toshiba A205-S5809 Wont power on
Toshiba A205-S5809 Computer Laptop will not power on. I tried unplugging the power chord and hold down the power button for 15 seconds. This did not work I also tried removing the battery with the power chord plugged in and held down the power button for 15 seconds but still it did not power on.
  • Toshiba Master
  • 7,627 Answers
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Posted on Jan 08, 2013
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
  • 43 Answers
SOURCE: I have a toshiba satellite A205-S5809 and after a
A bios update should not cause the laptop to fail in powering up. Regardless, whether you used the correct bios update or not, the laptop should still power on. You may not be able to boot to windows, but you should still power up.
You are have hardware failure unrelated to bios change.
Posted on Oct 31, 2009
leusnerdus
  • 54 Answers
SOURCE: I have a Toshiba Satellite A105 laptop that will not power up.
Get sure the memories are good. then try reseting the BIOS by removing the BIOS batery, let it out for 5 minutes and place it again. Though you have to disassembly almost the whole laptop. If dont, chek the other "pheripheral" devices, HDD, DVD, and another (If)
Posted on Apr 20, 2010
SOURCE: Toshiba Satellite Pro 4200 stuck in hibernate.
I have a toshiba satellite pro 4200. I have put a new memory module 128MB in in addition to the 64MB memory that was already in. The system does not recognise the 128 and the 64 modules when installed together. Do the two modules have to be of the same value i.e. 128 or 64 or is there another way of getting the system to recognise both modules. Many thanks BB
Posted on Apr 30, 2010
  • 13433 Answers
SOURCE: http://www3.dealtime.com/Toshiba-Satellite-A205-S5...
Manufacturers use the same computer case on many models If the bay is empty, there are no connectors, then basically your motherboard model does not support a 2nd hard drive. And those connectors and components have not been build into this motherboard.
You have a empty slot in the case but there is no hardware to connect the drive to.
You are stuck on 1 drive.
Put in a 120GB SSD drive for example and then use external usb hard drive.
Posted on Nov 21, 2010
Toshiba a205 wont enter into recovery mode
with the computer off. start by having it plugged in. now press and hold down the 0 (zero) key. while holding it down press and release the power button.. as soon as you see it power up release the 0 (zero) key. this will restore to out of box state. it will take aprox and hour. You wont have to do anything just let it run the restore..
Apr 03, 2011 | Toshiba Satellite A205-S5804 PC Notebook
I need Windowa XP Drivers for Toshiba Satellite A205-S5809 PC Notebook
Click Here and on the new page, click "All Operating Systems", select "Windows XP" and download the drivers one after another.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 07, 2011 | Toshiba Satellite A205-S5809 Notebook
My laptop wont come on. where it shows the battery charging is just a yellow flashing light now
actually the battery is empty so plz connect the charger and then try starting it
Sep 17, 2010 | Toshiba Satellite A205-S5809 Notebook
I have a toshiba satellite A205-S5809 and after I installed a RT8187B wireless network card. The system will not boot. Any suggestions?
try to do system restore
restart the computer and press F8
select safe mode and wait until it loads
on your desktop
click start > all programs > accessories > system restore and select the date that your computer is still working fine
hope this help =)
Sep 07, 2010 | Toshiba Satellite A205-S5809 Notebook
I have a toshiba satellite A205-S5809 and after a bios upgrade it will not power up. Can anyone help me?
Oct 31, 2009 | Toshiba Satellite A205-S5809 Notebook
Will not boot
Try to enter into bios by pressing Del or F2 or F10 ..while booting ..
Oct 04, 2009 | Toshiba Satellite A205-S5809 Notebook
Downgrade to Windows XP.
Due to the fact of the many people that wish to downgrade to Windows XP, many computer distribution companies keep current driver software that is compatible with the various Windows OSes. I checked the Toshiba website for drivers for the Satallite A205-S5809 and they have drivers for WIndows XP, XP SP2/SP3, Vista 32-bit, and Vista 64-bit. They have all the drivers you should need to make the changeover. I hope this helps.
Mar 23, 2009 | Toshiba Satellite A205-S5809 Notebook
THE LAPTOP JUST SHUTS IT SELF DOWN
Check if the cooling fan is actually turning on or if the exaust is cloged with any derbis. If so, you should try cleaning them and later observe if it works. However, if the cooling fan fails to run you should replace it.
Mar 22, 2009 | Toshiba Satellite A205-S5809 Notebook
Open Questions:
Toshiba Satellite A205-S5809 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
