My altise OMEGA 45W TOWER FAN cannot power up
When i press power on button, it's only turn on one second then off.
  • 7,627 Answers
That sounds like a bad PSU. Open the machine and clean if needed.
Posted on Jan 09, 2013
  • 523 Answers
SOURCE: Press power button. Green light turns on, fan
there is power buttom on the keyboard makes it wake up. try it
Posted on Oct 03, 2009
SOURCE: When the computer on/off button is pressed , the
if you have added any new hardware recently please remove it and check whether your PC boots up
Posted on Sep 12, 2010
  • 140 Answers
Plz check your SMPS and Motherboard
Posted on Sep 13, 2010
RescueTechLA
  • 2653 Answers
SOURCE: power tower wont turn on. when you press the power
First thing I would check is the power supply, easiest way to test it is to just swap the power supply with a working one.
That's easier said than done if you're just an average user so unless you've got an extra power supply handy then I would suggest finding a local computer repair shop that provides FREE DIAGNOSTICS, most do these days. Have them check out the system. It's either the power supply or motherboard. HOPEFULLY it's just the power supply though ;)
If the repair shop says it is the power supply I'd sincerely thank them for their time (5 minutes) and then I'd buy a replacement power supply and install myself ($15-25)
Hope this info helps!
Posted on Oct 07, 2010
JaxPlanet
  • 922 Answers
SOURCE: I have a Dell Dimension 4600. I press the power
The most likely cause is a failing power supply. Unless you have a tester you will need to buy a replacement. Check the specs and order a suitable replacement. (www.newegg.com is my choice)
If any of this goes past your computer knowledge take your computer to an expert to examine first-hand.
Posted on Dec 26, 2010
How can I tell if my power supply is bad?
Switch the machine off and leave it unplugged from the mains for 5 minutes, while it is unplugged press the power on button a couple of times. (This will make sure all of the logic in the tower is reset, ) Then turn it on again. The only way to test a power supply is with a multimeter or a PSU tester, the second one is easier and cheaper. (about 5 to 10 GBP)
Apr 20, 2013 | HP Pavilion a310n PC Desktop
Nokia 1110 tower problem
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 28, 2012 | Nokia 1100
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
    Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
    E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
    However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
    1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
    2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
    3 Wait for the washer to run a short diagnostic test.
    4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
    Jul 30, 2011 | Washing Machines
    When I push the start button then the leds going on and the fan just start for 5 seconds, than the power is stop. Can you give me advice about my desktop HP 330ut.
    before doing anything please remove all the cables (mouse, keyboard, power, VGA everything) from your tower.
    then press and hold the power button for 10 seconds.
    then connect all the cables. and turn on your computer.
    if problem persists. you need to consult the technician becuase that is a hardware failure.
    Jun 27, 2011 | HP Compaq d330 (DG315A) PC Desktop
    There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
    If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
    Turn off the computer by pressing on the power button on the system tower for 10 seconds.
    Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
    Reconnect the power cord and then power on the computer to see if the issue is resolved.
    Thanks for using Fixya
    Proton
    Aug 30, 2010 | Dell XPS 200 PC Desktop
    My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
    1. Turn off computer and unplug power cord.
    2. Disconnect all external devices(open up the computer tower and then )
    3. remove battery
    4. press power button and hold for 10-15 seconds
    5. plug power cord back into computer and press power button.
    6. Check LED’s and listen for power supply fan.
    7. If LED’s are on or power supply fan starts spinning, watch for boot screen
    8. If coputer begins to turn on, turn it off.
    9. Reconnect battery and external devices.
    10. Press power button and make sure computer starts.
    This should work....all the best
    May 19, 2010 | Computers & Internet
    My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
    Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
    Now keep on holding down the power button on the computer tower for 15-30 seconds..
    Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
    If it works, great!!!
    Otherwise, take it for repair..
    Dec 03, 2009 | E-Machines eMachines Desktop PC
    My tower won't turn on. I checked and it is plugeged in to a working outlet... the screen light is on and even one light on the tower is on -- but when I press the on button NOTHING happens.
    hi ,
    you can try this solution
    unplug all cables , powerflee the system by pressing the start button for 30 sec , release it then replugg all the cables and check wheather it is working or not , secondly check wheather the powers supply fan on the back of tower is working or not, still it doesnt work turn off the tower and unplugg the tower and then openthe tower , check all cables and reset the RAM on the mother board ...you can try this basic troubleshooting , it will help u... waiting for response
    May 20, 2008 | Computers & Internet
    Computers & Internet Logo
    43 people viewed this question
    David Payne
    David Payne
