Question about Panasonic PT-AX200U Projector
Panasonic PT-AX200U projector. input display flashes on and off.
I am trying to set up a used Panasonic PT-AX200U projector. All that is happenings that the blue screen shows, and the input display flashes on and off. /i can set it to the right input, but when I push enter nothing happens. It just conitnues to flash the image for the the input choices. Any idea what is going on?
  • Panasonic Master
  • 3,904 Answers
It could be your source and not the projector. If it is a laptop then hit function four and change how it shares display. Over all I need more info as to how it is plugged in and what you are trying to view from.
Posted on Jan 10, 2013
SOURCE: blue spots on screen
Obviously this is not the first lamp you have replaced in you projector. These are great projectors however, the LCD panels expire quite quickly. You will find that the spots are related to the LCD panels needing to be replaced. This is not an inexpensive maintainence solution as the panels cost about $1500 each.
Posted on Jan 25, 2008
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
SOURCE: Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Posted on Nov 28, 2009
SOURCE: Panasonic PT-AX200 lamp problem
i also have, mine did this but switching the dynamic iris off solves it.
Posted on Jan 28, 2010
SOURCE: panasonic projector pt-lm2e
I have Panasonic Pt-LM2E projector and it have a pblm,when it goes standby mode after some time (5-7minutes).no other indications shown (eg: lamp,temperature ).pls give a solution for this
Regards
Siva
Posted on Jun 28, 2010
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
I have a PT-AX200U projector, I have noticed that the picture is diming intermitently
how may hours has your lamp done?
if you have crossed more than 1500 hours , u may need to change the lamp.
the problem could however be that of the signal cable which could be intermittent and causing similar fault.
check if the same problem is seen in all inputs!
Dec 24, 2012 | Panasonic PT-AX200U Projector
I just replace the lamp in my projector and it is still darker in the middle of the screen. It appears there may be dust on the internal lense but I do not know how to get to it.
It seems that most everyone who owns the Panasonic PT-AX200U has this problem. I believe it is on the lens inside on the glass. I'm not sure how to get to it either. Maybe this forum will help.I'm going to read it now. http://www.avsforum.com/avs-vb/archive/index.php/t-1166504.html
Apr 20, 2011 | Panasonic PT-AX200U Projector
PT-AX200U Bulb replaced 4 months ago Was on about
carefully take the lamp cover off, and see if there is any glass pieces inside. if all looks Ok, then unscrew the lamp housing and remove the lamp. check for any damage. be careful not to damage the lamp or bump it. These lamps generally contain mercury vapour, so try not to inhale anything if it's broken.
Apr 09, 2011 | Panasonic PT-AX200U Projector
Pt-ax200u projector turns off after 1 min of operation. the light turns red then green. After that, the power button does not respond and i have to cycle off the project. If I turn it on, it does the same...
your projector is detecting it is overheating, check that nothing is blocking the vents and that the fans are not clogged. If the vents and fans are dirty clean thema paintbrush and hoover. If they arent then the lamp maybe the culprit
Mar 07, 2011 | Panasonic PT-AX200U Projector
My pt-ax200u runs for about 15 mins then turns off. The replace bulb light is on but otherwise vents are cleaned and and cooling fan is running.
hi,
try one thing reset ur projectors lamp hour and the try
follow the procedure for lamp reset
1. power on the projector
2. press the menue button
select options and then press enter
select lamp rutime
press and hold enter buttonfor 3 seconds
confirmation screen will display and select ok
press power buttonfor turn offfor resetting the duration of the LAMP RUNTIME
confirm theduration of time in lamp run time
Jan 06, 2011 | Panasonic PT-AX200U Projector
HDMI inputs do not show a picture. They worked but now do not. They display the setup program from the Onkyo AV receiver via HDMI output, but not when the receiver is pushing any other signal via the...
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
Aug 21, 2010 | Panasonic PT-AX200U Projector
HOW DO I REST THE BULB LIFE ON MY Panasonic PT-AX200U
1. Press the MENU button to display the menu.
2. Select the OPTION menu and press the ENTER button.
3. Select LAMP RUNTIME.
4. Press and hold the ENTER button for approximately 3 seconds.
5. The confirmation screen will be displayed and select OK.
6. Press the POWER button to turn off projector for resetting the duration of the LAMP RUNTIME.
7. Confirm the duration of time in LAMP RUNTIME is reset to “0 H”.
Aug 05, 2010 | Panasonic PT-AX200U Projector
Hdmi inputs does not show a picture. The inputs just stop working.
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Jun 28, 2010 | Panasonic PT-AX200U Projector
Panasonic PT-AX200U Projector Logo
136 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
