Question about Fitbit Weight Tracker
How do I open the back to place battery?
I was able to move it to the unlock position but it wont pop open.
My sunroof is stuck open its acting like it wants to close but goes back
If you have a 740 with an electric sunroof, when the roof is in the fully closed position you should be able to push the closed switch again and have the rear of the roof pop up to the 'vent' position. If you have a manual roof, after it reaches the closed position you feel a bit of resistance; you then continue moving the crank in the closed direction and the rear of the roof should pop up to the 'vent' position.
If your roof does not move at all, you must NOT pry up the rear edge manually as there are cast tracks at the rear of the panel that hold it in place and you will break, bend, or damage the tracks, roof or the panel.
Most likely it is out of alignment and too tight for the minimal leverage applied by the motor to move it, as well as being thoroughly gunked up. The secret to lack of motion is most likely binding in the up and down motion of the panel. If manual, try moving the crank back and forth, bearing in mind that the first motion the roof makes is that up and down motion at the rear of the panel. If there is resistance to the crank motion immediately, there is 'likely' to not be any damage in the screw mechanism, just binding of the panel in the roof.
If nothing moves as you move the crank towards 'vent', push up gently through that small rectangular opening inside the headliner on the rear of the panel to help it along, by just pushing it free of the roof. The tracks at the rear of the panel move the panel up and down, either to pull it down before retracting or to pop the rear of the panel up for the 'vent' position, and if they are damaged or too gunked up, they will resist opening. The device that is connected to the motor/crank via screw cables slides back and forth in these tracks, raising and lowering the panel, which will not be possible unless you can move the crank/motor. Try to get it high enough to be able to peer inside the roof from the outside to unhook the headliner clips - once you get those, all is revealed and you will be able to see why your roof is not functioning properly.
Try a few links to help further:
http://www.swedishbricks.net/700900FAQ/Body-Sunroof1.html
BMW Sunroof Removal and Repair Wayne Dempsey
Great now my sunroof wont close TDIClub Forums
Club Scion tC
Sunroof problems Mercedes Benz Club of America
Apr 13, 2015 | Cars & Trucks
Electric latch on the rear Hatch door will not unlock
I guess ford was trying to make a couple more bucks by not putting key locks on all doors. Anyway, if you crawl inside and pop the small cover(about 2"x2") off the inside of the hatch where the latch is located you can reach in with a screwdriver and manually move control arms. The lever on the back/far side of assembly is in the locked position, you need to move to the opposite side left or right of it's current position, this will unlock the latch and should allow you to open the door. You mave have to pop acutor arm loose to move it. My problem ended up being the outside cover {license plate frame)seal had been damaged by a ford mechanic, that or it was defective. Water got in and damaged the the lock acuator. Had to replace entire assembly as ford does'nt offer just the acuator. Sealed the outside cover with clear silione.
Try this link for more info:
tailgate 2004 Ford Freestar
Check similar answers at this site:
2005 ford freestar back hatch door wont open
Apr 11, 2015 | 2004 Ford Freestar
Oven latch will not open
Sometimes the latch arm is bent causing the latch release not to clear the hook on the door. If the arm goes under the front it is probably bent. Carefully pull the arm back toward the locked position and try to bend it back a small amount and see if the door will open after moving the arm back to the open position. If that fails sometimes you can insert a bent coat hanger between the door and the latch hook and move the latch enough to unlock the door. I hope this helps
Nov 28, 2013 | Ovens
Camera is somehow "card locked"
The SD memory card should be located where the rechargeable battery is, remove battery cover, should be a small tab holding the memory card in place, move it so the card pops up, remove it and look along the one edge for a switch, slide it towards the contacts to unlock the card. The switch that is furthest from the contacts is in the locked position. Now if you find the card is in the unlock position, slide it back and forth to reset, failing that replace the memory card. Sometimes the slider switch becomes defective locking out the card.
Aug 15, 2011 | Cameras
Can not remove the battery cover for my X3... it wont pop out when i move it to OPEN position
you have to use some pointed or flat tools to open it. you had to pull it out. i hope this will help you.
Aug 11, 2011 | Suunto X3HR Wrist Watch
Door locks move a little but wont go all the way to the lock or unlocked position
Pop off interior door panels & lube up door lock actuators with a good penetrating oil, move lock buttons back & forth manually & try to use switch to move back from unlock then to lock & back in forth. If they will not free up you will need door lock actuator.
Jul 11, 2010 | 2000 Ford F350 Super Duty Super Cab
Key wont' remotely lock/unlock (new batteries)
place key in ignition turn ignition to run position
hit the butons on remote it should re prog the remote
if remote got wet or dirty open up remote and clean contacts
Jan 22, 2010 | 2003 Audi A6
Keyboard on my Dell studio 15 is locked
Use your touchpad or mouse to save all open documents and close all programs. Shut down the computer. Be sure to click "Turn Off" instead of "Restart."
Unplug your Dell Inspiron 2600 and close the lid.
Carefully turn the laptop over. Remove the battery. The battery has a sliding latch and lock. Unlock the battery by sliding the lock to the unlock position. Slide the latch and remove the battery when the left edge pops up.
Wait one minute and replace the battery. Slide the lock back into the locked position.
Connect your adapter and restart your system.
Sep 13, 2009 | Dell Computers & Internet
TAILGATE WONT OPEN
yes take off the inside panel and move the rods connected to the lock to open,,if thers no rods and its electric then its more tricky ,you need 2 get a power pack or something that has a positive and negative lead and strip some of the wire going in to the lock then just touch them with both leads to pop it,,,
Apr 20, 2009 | 2000 Ford Excursion
HP Pavilion dv2120us Notebook PC battery release latch
My battery latch got stuck in the open position after replacing the battery on HP's DV 6300 series. The battery was thus stuck. I used the 'screwdriver' technique but with a rounded end kitchen knife not an actual screwdriver to remove the battery. It is important to push the knife down a little into the groove at the outer long edge of the battery and pry that outer edge up. AFTER DOING THIS THEN GOING TO REPLACE THE BATTERY I REALIZED THE LATCH PROBLEM OCCURRED BECAUSE I HAD PUSHED THE BATTERY LATCH TO THE OPEN POSITION TO REPLACE THE BATTERY. THIS IS WHAT JAMS IT. TO REPLACE THE BATTERY 'DON'T TOUCH THE LATCH AT ALL'. LEAVE THE LATCH IN THE CLOSED POSITION AND REPLACING THE BATTERY WILL SET THE LATCH IN THE CORRECT CLOSED POSITION, READY TO BE SLID TO OPEN POSITION ONLY TO DO THE ACTUAL BATTERY REMOVAL.
Dec 13, 2007 | HP Pavilion dv2120us Notebook
Fitbit Weight Tracker Logo
43 people viewed this question
Top Fitbit Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Fitbit Facebook App Expert? Answer questions, earn points and help others
