Question about Toshiba Satellite Pro S300-S1001 Notebook
Cmos battery location on a toshiba pslc8u-03701q
  • Toshiba Master
  • 7,627 Answers
  • 2427 Answers
SOURCE: cmos battery
Hi ,, the battery is located on the main board.(I think you know this) eighter under the keyboard or in the back. You will need to open it up, First take the hinges off by prying it up(the piece that connects the screen to the computer) You will then find the screws that holds the keyboard in place. Take these out as well. Now if you dont see your battery, Turn the laptop over, remove the rom, hd, and rams, (there are a few screws holding them in place then slide them out). now remove all other screws and lift the back cover off there is your mainboard and the battery sould be there.
Here is a Disassembly guide complete with pictures. It describes step by step how to take apart the laptop safely and then follow the instructions backward to reassemble it. This is where i brought my manual from
Click HERE
Posted on Nov 03, 2008
  • 13 Answers
SOURCE: want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Posted on Mar 03, 2009
SOURCE: Trying to locate the cmos battery for Toshiba Satellite L25-S121 laptop?
On the Toshiba Satellite L25 S1217 Laptop, the battery is indeed to the left of the wifi card. I was having a problem with a bios password and had spent a considerable amount of time looking. However Instead of taking the whole laptop apart, I removed the wireless card and used a precision flathead to maneuver the connector out of it's socket. after a few seconds I booted the laptop, with the battery still disconnected , and no password prompt! using the same screw driver, I was able to get the connector back into it's socket, and put the wireless card back in. it runs fine now. the trick is to only pull the connector out only enough so that it's not making the connection, if you pull it too far you will have a tougher time guiding it back into the socket. I hope this helps a lot of people with the same problem.
Posted on Apr 30, 2009
  • 58 Answers
SOURCE: Toshiba Satellite A100 755 battery CMOS
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
50
Posted on Jul 26, 2009
parrotheadpc
  • 2600 Answers
SOURCE: cmos battery location
Below is the link just copy and paste in the browsers address bar. Scroll down to chapter 4.15 which is the RTC Battery. Good luck, ParrotHead PC Repair
http://tim.id.au/laptops/toshiba/satellite%20a40.pdf
Posted on Sep 05, 2009
I did a factory reset on my toshiba satellite model number PSLC8U-03701Q laptop and after the reset a box is coming up stating..install windows The computer restarted unexpectedly or encountered an...
When you reset ...you need to reinstall windows...you will probably have a boot partician on your hard drive or if you have the disc reinstall
Sep 08, 2014 | Computers & Internet
Toshiba PSLC8U-03701Q factory restore
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to
hope this helps you
Mar 18, 2012 | Toshiba Satellite L305D Notebook
The screen quit working. the computer will turn on the fans are working and all but the screen has no power to it what so ever the serial number is 19524318q the model number is pslc8u-03701q
Have you registered this laptop? if it is still under warranty you should get in touch with Toshiba. it sounds as if the motherboard has gone out. I just replaced one on a HP that had the same problem.
Dec 20, 2010 | Toshiba Satellite L305D Notebook
Where is the cmos battery located?
It is located on the mother board, under the keyboard.... It is the size of a quarter.... and may be soldered in on your Satellite M35x series machine.
Oct 23, 2009 | Toshiba Satellite M35X-S149 Notebook
BATTERY CMOS LOCATION TOSHIBA SATELITTE L300
battery cmos location in toshiba l300 insid the motherboad in leaft side near in hdd but you should open all the reset it if necessary/
Jun 26, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba A135-S4527 cmos battery dead
I found where the cmos battery is located. By the Toshiba tech support website , it's next to the PCMCIA Slot, just behind it. To get to it, Take off LCD, keyboard, top palmrest, hard drive, battery, memory, top power cover,switch board, modem, network. and some others. Too many to describe here. Items to remove not in order.
I Have the service manual downloaded already.
Let me Know
comier957
Aug 07, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite Pro S300-S1001 Notebook Logo
369 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
