Question about Panasonic TH-50XVS30 Television
NO SIGNAL I COULD SEE THE VOLUME MENU BUT NO PICTURE ONLY A NO SIGNAL ON TOP RIGHT OF SCREEN
  • Panasonic Master
  • 32,281 Answers
Check the antenna connections, re-plug the connections.
If this does not fix the problem. try a different antenna lead, also check the antenna.
Posted on Jan 08, 2013
  • FRANK TORRES Jan 08, 2013
    its no the connection i traid a different tv an the cable is fine
  • Chris Hingee
    Chris Hingee Jan 08, 2013
    Check the input selection, it maybe set to the wrong input connection.
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
My olevia 242 has picture but no sound what can i do
The basic things to do are:
1. in menu make sure speakers or volume is on--speakers first.
2. if using a box for signal make sure volume is not off there.
3. Check to see if volume goes up on screen display when you activate the remote and buttons on the set.
4. lastly put your ear up to the speakers and see if you hear anything at all--even a low volume or a hum.
Mar 13, 2012 | Televison & Video
I have a black in the top right hand of my tv
msarnowski,
If you mean you have a black square in the top right hand of your picture, it sounds like the Picture in Picture feature is turned on and there is no signal to the tuner, which will show as a black square somewhere on the screen.
Open the menu and check the setting for the picture in picture feature. This could solve the problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Aug 30, 2010 | Hitachi Televison & Video
TV has sound..no picture Philips DPTV335 was working fine and suddenly picture went out. Still has sound but nothing on screen (volume bars, picture)
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Mar 21, 2010 | Philips Magnavox MWR10D6 DVD Recorder
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Mitsubishi 55" - Stretches screen
on the frount you should have ch up , ch down,
same for volume , and menu. press menu
and scroll down to VIDEO or SET UP
try one of thoes sub menu will have FORMAT
4:3 - 16:9 seting its a little differant on
on same make diferant models , you may
have to do a little hunting to find the setting
Jul 02, 2009 | Mitsubishi WS-55807 TV
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
sorry dry solder joints this model was a disaster for this not worth repairing
Oct 12, 2007 | Toshiba 32A35 32" TV
Vertical control of viewing frame needs adjustment.
Did you try going into MENU --> PICTURE --> SIGNAL MODE, and then pressing > to go through all the signal modes? On mine, most of the signal modes split the screen weirdly as you described, but one of them (in my case XGA3, but I'm not using a Mac) looks right.
Nov 07, 2006 | Polaroid Polaview 211E Multimedia...
Panasonic TH-50XVS30 Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
