Question about Sharp Office Equipment & Supplies
Sharp mx 4100n error code L4-45
Locked up giving error code L4-45
  • paulostmg Jun 16, 2017
    Toner cooling fan problem. There are two cooling fan right above the black developer unit. It is hard to tell which one has an issue. You need to replace both of them. Here is the part number. NFANS0085FCPZ TONER COOLING FAN.
  • Sharp Expert
  • 337 Answers
P, * , CA , P then enter sim # 14 to reset code.
Posted on Jan 30, 2013
5 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: our sharp mx-m450N gives us error code u2-11. what
EEPROM read/write error (serial communication error)
Posted on Jun 06, 2010
janalyn_glov
  • 58 Answers
SOURCE: unlock password Problems for sharp mx-2300g
Here's a link to a site that has the user manual. It's free to download, but you'll need Adobe or Nitro PDF reader to open it. I found the instructions for the same thing for my copier in its' manual. Good luck!
Posted on Aug 31, 2012
dwylie76
  • 80 Answers
SOURCE: Our Sharp MX C311 gives
sounds like your NIC card is bad, no network cable plugged in or the network port in the wall is not an active network port.
Posted on Nov 10, 2011
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
For the last few weeks, my 5 year old LG 2487HRMA, has been giving me de code errors shortly after starting. It is because the lock light just goes from red to off for no reason.
Lift up the top of your washer and there will be a code and test sheet in there that will help lead you to fixing that problem, almost sounds like it went into the its own test mode.
Jan 09, 2016 | LG WM2487H Front Load Washer
H5-01 ERROR CODE
The following is from the Sharp website on error codes: SHARP MX M503N ERROR CODES Trouble Codes
H5 01 = 5 TIMES CONTINUOUS POD 1 NOT-REACH JAM
Mar 03, 2015 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
Sharp MX 4100n giving L4-16 error msg
Your machine has automatic fuser pressure control. It's supposed to release pressure when you shut it down, and reset it on startup. This is done by a combo of a motor & gear on the machine and a gear on the fuser. Somehow this has gotten reversed or jammed. you need to take the fuser out and make sure the gear is in the right position and that no rods are in the way (there's a cleaning rod resting on your lower fuser roller, often this will tuck under its' mounting rode and wedge)
Apr 02, 2014 | Sharp Office Equipment & Supplies
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
Reset password for administrator
You can reset the administrator password, but it's recommended that you have your servicing dealer do this for you as it involves getting into the system menu etc.
Here is a link to a blog entry with the default administrator passwords in case you haven't tried them.
Sharp Printer Default Administrator Password
Dec 18, 2013 | Sharp "MX-4100N Copier, Printer, Scanner...
Sharp MX4100n driver software freedownload
You can download Sharp print drivers directly from this link. Both 32-bit and 64-bit drivers are available for download here on this page along with instructions for getting them installed.
Sharp Print Driver Download 64bit and 32bit Free Printer Driver Download
Sep 23, 2013 | Sharp "MX-4100N Copier, Printer, Scanner...
2,212 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
