Question about Toshiba Satellite A505-S6970 Notebook
Toshiba Satellite A505-S6970 pci bus 4 function 1,2 code 28
5 Suggested Answers
MOROO007
  • 180 Answers
SOURCE: toshiba a105-s4054 won't boot
The same machine with me and the same problem I changed the BIOS of the motherboard but the problem Tlch the same message is is the last day I discovered that the problem in the chip of Intel's motherboard happens is a conflict between the PCI and Ridr and some of the various components that vary according to the case of the slide as this occurs in the organs contained in the slide as happens conflicts in the delivery at the beginning of operation of laptop and since all the inconsistencies that occur when you start up that is stored on the memory the BIOS and therefore must be emptied this memory so that the laptop from work and not doing a re- choose to run the key F-1
s this memory chip in it's protection for the BIOS that is stored by BIOS password
Points for this memory on the motherboard when you connect to these points is clear all data from storage on a slide in the Model 100 is a satellite point of discharge under the Wireless card under the keyboard and be written next to 88 **
As for in this model are under-Ram
Posted on Apr 20, 2010
  • 731 Answers
SOURCE: Toshiba Satellite A505-S6970 PC Notebook shut down
Is this using battery power or the wall charger?
If on battery power could be battery not holding charge... replace it
Make sure the machine will run on the power adapter without the battery in or it could be the adapter.
If it runs with or without the adapter and the battery is good it could be overheating and going through "Thermal shutdown"
This will be noticable by excessive heat and once it cools down you will be able to restart it.
Thermal shutdown can be cause by a bad fan or dust blocking the vents.
A can of "canned air" can be purchased for less then $10 and you can try blowing out all the vents.
However if the fan is bad it will need to be replaced
Posted on Dec 14, 2010
  • 8909 Answers
SOURCE: my toshiba satellite model A505
All that you need is to be found at www.toshiba.com
Just follow the instructions on screen.
I wonder where you got the BIOS flash from, as if you use www.toshiba.com the connection takes you to the correct BIOS.
Hope you can recover it alright.
Posted on Mar 30, 2011
abdulkarimap
  • 149 Answers
SOURCE: A505 S6970 Toshiba laptop HDD#1/SDD#1 password
Maybe you mean log on password. If you never enter a password to log on, but suddenly when turning on the computer, you are prompted to enter a password to log on, but always failed. You try to log in using an administrator user but failed. Chances are, the operating system is infected with viruses.
So, the operating system has controlled the virus.
solution:
Install the new operating system (not repair the operating system)
Posted on Nov 28, 2011
How do I setup audio input on a toshiba satellite labtop
What audio inputs? On a laptop, hardware wise, your input are pretty much fixed.
Jan 15, 2013 | Toshiba Satellite A505-S6970 Notebook
solution:
Nov 27, 2011 | Toshiba Satellite A505-S6970 Notebook
Where can I get a guide to replace LCD panel on a toshiba satellite a505-s6973?
Hi klkdaddy1
TOSHIBA SATELLITE A505-S6970 NOTEBOOK LCD PANEL DISASSEMBLY GUIDE
The general LCD Panel Disassembly Guide for Toshiba notebooks like your can be found here:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/replace-LCD-screen-1.htm
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 07, 2011 | Toshiba Satellite A505-S6970 Notebook
My toshiba satellite model A505 S6970 having problem of restart it gets restarted auto and displays the bios screen its bios has been corruopted kinldy advise me to download the latest bios setup that will...
Mar 30, 2011 | Toshiba Satellite A505-S6970 Notebook
My toshiba a505-s69803 stopped taking a charge. Battery is fine. Is it the cable or something in the laptop iteslef.
IF YOUR BATTERY IS FINE, IT WOULD BE YOUR POWER SUPPLY PROBLEM, SO U NEED TO CHECK IT BY VISITING ANY ELECTRONICS SHOP AND CHECK THE OUT PUT VOLTAGE OF IT
Dec 15, 2010 | Toshiba Satellite A505-S6970 Notebook
Toshiba Satellite A505-S6970 PC Notebook shut down often. Does anyone know why ? and how can I fix it ?
Dec 14, 2010 | Toshiba Satellite A505-S6970 Notebook
Toshiba satellite a505 s6960 The service is temporarily unavailbe MSN How to Fix That ?
You can't fix it, the problem is outside your laptop: either the connection is blocked by the firewall of a router - try disabling it or connect your laptop to another one- or a server from MSN which has your account on it is actually down and you must wait for it to be fixed.
Jun 19, 2010 | Toshiba Satellite A505-S6970 Notebook
I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
Aug 03, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Toshiba Satellite A505-S6970 Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
