Question about Saeco Classico Espresso Machine
Steam still coming through brew group even when pump not ON
Have a Saeco Classico machine that made great coffee but now it has BURNT me, literally.
Problem is: Even after the espresso pump is in off position their is stem eminating from the where the brew basket would attach. IT comes in fits and bursts, like there was a damaged gasket leaking steam out of boiler.
Danger: Made a cup of espresso, left the basket on, went back 30 mins later to make some more. Unscrewed the handle and a burst of hot water and steam scalded my hand and shot grounds all over. Looks like a nice head of steam had built up.
QUESTION: What is wrong? Can it be fixed and is it worth taking into a service center. My max repair budget is $150.
  • turbo290 Mar 20, 2009
    Apparently this is a common problem with these machines. Mine does the same. I had it fixed once before and it simply requires a small o-ring replacement. Cost was approx $70.00 but it was all labour. O-ring was .50. I need to find out exactly where this o-ring resides and how it can be replaced.
    Thanks
  • 4 Answers
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
Posted on Feb 17, 2009
Hi, My Saeco Vienna isn't working so great. When I start it up, it makes no brew-group movements and the red light goes on, as well as the water light. Both are displaying solid lights. it won't go in
If every component is in it's correct position and the brew group makes no or very little movement upon start up, it means the 33v DC converter on the CPU is probably bad and the board will need to be replaced. Or, one of the microswitches in the gearbox could also be broken or malfunctioning. Either way, with the symptoms you've described, I believe you will need to have the machine serviced by a Saeco Certified technician. The repair should cost between $175 - $225 unless there are multiple issues.
Dec 08, 2014 | Saeco Vienna De Luxe Espresso Machine
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
My Saeco Classico won't brew
Have you run a backwash on the group with espresso machine soap?
If no then remove the shower screen in the group and clean (that might be covered with coffee oils).
Jul 17, 2009 | Saeco Classico Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Jun 03, 2009 | Saeco Easy Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
www.CeriniCoffee.com
May 28, 2008 | Saeco Classico Espresso Machine
Saeco Magic De Luxe - hot water / steam but no coffe through the brew group
our taking about the plastic piece with 2 seal on it if it that its very easy to change that thing is screwed in the boiler try to unscrew the piece if you cant you gonna have to remove the boiler i know does machine good let me know thanks for using fixya pierre
Feb 13, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Classico Espresso Machine Logo
181 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Shehu Pro
Shehu Pro
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
