Question about Toshiba Satellite Computers & Internet
Ttoshiba l350 bios password locked by ex girlfriend when i enter my serial no into pw generator which is 19020458Q it say's i have an acer,hp and generate's 06988498 which dos'nt work am i
If i am entering the wrong numbers can you put me onto the corect way to generate the corect password thanks in advance
You could try taking your cmos battery out of the laptop for 15 mins or so and try again.
Posted on Jan 08, 2013
  • 5 Answers
SOURCE: hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Posted on Nov 05, 2007
  • 61 Answers
SOURCE: Bios Password Reset
The only idea I have is to find and disconnect the CMOS back-up battery after removing main battery and unplugging the AC adapter. That SHOULD clear the bios completely, wiping out the password, the date, and everything else.
I know this works on desktops, and most laptops, but no promises, and the cmos battery may not be easy to access.
You should probably leave the battery unhooked for at least 1-2 minutes to be sure it clears.
Hope this is some assistance!
Posted on Jan 18, 2008
bhagyavichar
  • 414 Answers
SOURCE: I changed bios password on 4005
i'll try make it simple..disconnect all input mains power sources.."just remove or pick open the cmos battery (+3v) from the main/mother board and resit/fit it again carefully"..
configure bios again..save n exit n restart..hope it'll work..
always better to hv professional supervision, contact ur system admin/vendor....
Posted on Nov 01, 2009
SOURCE: bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Posted on Aug 09, 2010
  • 1116 Answers
SOURCE: I have older Toshiba laptop
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 01, 2011
Testimonial: "It realy works! Thanks!"
Reset power on password
If you feel comfortable doing so, remove the back panels that cover the wireless card, RAM, hdd, etc. You're looking for a small button-cell battery with two wires connected to the motherboard. If you see one in plain sight, you're in luck. Disconnect it from the board, remove your laptops full size battery, and make sure it isn't plugged into any power source at all. Leave it for 1-3 minutes. Reconnect the button cell battery (This is a CMOS battery and stores BIOS passwords ), plug the other battery or your charger in, restart laptop. Password should be reset, however some BIOS' hold it in flash memory.
If this is the case, look on the bottom of your laptop and attempt to find a serial number on a white label. it may be labeled s/n or something like that. Type this serial number in at (http://bios-pw.org/) and attempt to generate a master unlock password for your laptop. This works about 50% of the time for me. If it allows you to get into the laptop, the password generated will allow you to change all passwords in BIOS.
Dec 17, 2013 | HP Compaq nx6110 Notebook
Power password
Try looking for the CMOS battery underneath the plastic covers for the wifi card / RAM on the bottom of the laptop. They unscrew. You may see a small, button-cell battery somewhere that connects to the board with 2 wires. Disconnect this, and wait a few minutes. The power on password should clear.
Otherwise, try using the serial number to generate a master password at (http://bios-pw.org)
Sep 17, 2013 | HP Compaq Presario V5000Z Notebook
Toshiba l350 bios pw generator and how to read checksum
no way to genrate bios pw, you need to contact nearest toshiba service center
Jan 08, 2013 | Toshiba Satellite Pro L300-EZ1005X...
My HP mini 1000 is locked and I can't even get
Remove the cmos battery for 5 - 10 minutes. That will reset all data in the bios.
Jul 25, 2011 | HP Computers & Internet
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Jun 12, 2011 | HP Compaq 6730s Notebook
How to unlock password for a HP 2140 Mini-Note
If you are talking about the login to Windows password then here is one way to do it:
Create a bootable USB stick using this tool: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Use the image from Ophcrack to load onto the USB: http://ophcrack.sourceforge.net/download.php Choose the XP LIVE CD Option
1. Download the YUMI exe to your desktop 2.. Save the LIVE CD of Ophcrack to your desktop. 3. Plug in the usb stick you want to use (make sure it is at least 500MB. 1GB if possible) 4. Run the YUMI EXE and follow the instructions. Make sure to choose the USB Drive Letter ("D:" E:" etc) 5. Choose the Ophcrack ISO for the image. 6. Install to USB 7. Click Finished and exit the program and close any other open programs. 8. Restart the computer. Leave USB plugged in. 9. As soon as the computer restarts, tap the F10 button to enter the BIOS Menu. 10. Scroll to the Boot / Advanced Menu and change the boot order to USB first, HDD second. 11. Save and exit BIOS. Computer will restart. 12. Once booted up the computer will bypass the HDD and boot into the USB 13. elect Ophcrack from the list and hit Enter. 14. Follow the on-screen instructions to have Ophcrack force the password.
(If you're using Linux then use the Linux LIVE CD Image instead of XP)
May 03, 2011 | HP Mini 2140 Notebook
Hp mini 110 reset bios
If the bios don't have password just press F2 when booting, if have password need to open the machine and remove the CMOS battery (the battery is like a coin) for about 10 sec.
Dec 29, 2010 | HP Mini 1000 Netbook
My Acer some how got locked up in the CMOS. Need Password.
Hi there!
AMI BIOS
A.M.I.
AMI
AMI_SW
AMI?SW
BIOS
HEWLITT RAND
LKWPETER
PASSWORD
Oder
AWARD BIOS
01322222
589589
589721
595595
598598
aLLy
aLLY
ALLY
ALFAROME
aPAf
_award
AWARD SW
AWARD PW
AWARD_SW
AWARD?SW
AWKWARD
BIOSTAR
CONCAT
Condo
d8on
djonet
HLT
J64
J256
J262
j332
j322
KDD
LKWPETER
lkwpeter
PINT
pint
SER
SKY_FOX
SYXZ
TTPTHA
ZAAADA
ZBAAACA
ZJAAADC
Russian Award Passwords:
% p%
% p%
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot
PHOENIX BIOS
phoenix
OTHER BIOS
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
SOME COMPUTERS WITH TOSHIBA BIOS
Hold down the Shift key as the computer is booting.
I hope i helped you with this list i entered as much i could research by some of my books.
Please rate my answer! =)
Sincerelly
Aleksandar Adzic
Apr 16, 2010 | Acer Aspire 7720 Notebook
Phoenix bios password
The thing is that somebody set bios password. On phoenix bios based on intel platform? like yours normally if you will enter bios password incorrectly 3 times bios will lock the computer and it will generate 12 digit lock code. You will need to contact Toshiba technical support to get bios unlock password. (Normally this is generated by them within couple of hours.)
I would recommend you to check with toshiba support before locking bios (entering password incorrectly 3 times)
May 28, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
