Question about Dryers
Electrolux front load dryer does not start
Electrolux dryer does not start. Makes humming noise and stops. Drum does not move.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
If it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Posted on Jan 08, 2013
  • kkaradi
    kkaradi Jan 09, 2013
    Drum barely moves by hand. Pressing hard moves drum by half a quarter. I restart, same problem.
  • 58 Answers
SOURCE: When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
Posted on May 01, 2009
  • 5 Answers
SOURCE: Press the start button and drum doesnt start but
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Posted on Oct 23, 2009
  • 572 Answers
SOURCE: dryer drum will not turn
check belt
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: AEQ8700F Electric Dryer: My Electrolux dryer won't spin. The engine sounds ...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 20, 2010
heatman101
  • 43501 Answers
SOURCE: I have an Electrolux IQ
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Testimonial: "Thanks for the advice. Yesterday a technician came, said the same thing, took the cover off, spun the cylinder and it worked. Must have been blocked"
My electrolux front load dryer is making a squeaky and drum noise what could be the problem ?
Okay... Julia Agramonte,
Don't run it that way...!!
The drum has not been properly situated on TOP of the rollers...
This could be because of a rough move...
or improper closure of the case after "MAINTENANCE"...
(to speculate about possible reasons...
Open it BACK UP... and close it properly...!!
A MODEL number would be PROFOUNDLY
HELPFUL
in giving SPECIFIC answers.
Hope this helps.
Carnac the Magnificent
Jun 29, 2017 | Electrolux Dryers
Error 53 on electrolux front load model # EIFLW50LIWO
The E53 error code indicates low voltage to speed control board. Check the wiring between the main control board and the speed control board and if the wiring checks ok then replace the speed control board.
Jul 05, 2016 | Electrolux Washing Machines
My electrolux dryer was working fine and now it won't start
The hum normally comes from the motor trying to start turning but wont.....motor problem.
Jan 21, 2016 | Electrolux EIMED60LT Front Load Electric...
Dryer makes humming noise drum won't spin just goes back to pause
take out the plug and change the capistor ..make a note of the wires and take picture where they go
Aug 05, 2014 | Electrolux EIED55HIW Electric Front Load...
Electrolux eigd55hiwo dryer snagging clothes
First thing to check is the drum alignment to be sure that it has not shifted from wear. Open the door and reach in and see if you can move the drum up and down or side to side (not spinning) but pressing on it. IF you can then it needs to have some guides replaced. However if it is tight then you need to get a drier sheet or something similar and run it along every inch of that tub and the paddles and the back to see if it snags on something.
Jun 21, 2014 | Electrolux EIGD55HIW Gas Front Load Dryer...
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
May 01, 2009 | Dryers
Electrolux front end loader
How Old is the machine: Is it within the 5 year major parts cover? If so the drum bearings are covered.
Aug 26, 2007 | Electrolux EW1000i Front Load Washer
Dryers Logo
171 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
