Question about Toshiba TP50H60 50" Rear Projection Television
Toshiba TP50H60 Blinking Red Light
Hi there!,
I have a Toshiba TP50H60, which when plugged in, will show the word COLORSTREAM in blue on the screen and then go blank. It blinks its red Power LED also.  Any Ideas are appreciated :)
Adam
Pensacola FL
ctf1800
  • 4402 Answers
SOURCE: service manual TP50H60
http://www.eserviceinfo.com/
Posted on Dec 05, 2007
  • 1694 Answers
SOURCE: Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
Posted on Feb 01, 2008
  • 6 Answers
SOURCE: Toshiba 65H81 blank screen and red blinking light....help
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Posted on Mar 10, 2008
SOURCE: Blinking led light on Toshiba
wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
Posted on May 08, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Toshiba blinking light
Idle or changing modes?? (guess)
Jul 16, 2014 | Toshiba TP50H60 50" Rear Projection...
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
My toshiba tv screen looks 3D. red, green and blue outlining everything
carol_mccool,
You have a convergence issue. If trying to set the convergence does not work I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, where to get the parts and how to do the repair as well as links to additional information.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 27, 2011 | Toshiba TP50H60 50" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
I have a Toshiab 57H82 HDTV and when I connect my playstation 3 to the colorstream HD 2 input the colors are primarily green. In colorstream HD 1 the ccolors are fine, but its becoming a hassle having to...
If you have the wires switched GEEN,BLUE,RED on one end the color will be wrong. Check that the color off the wires are matched. Try a new cable. I've seen this a lot.
Nov 28, 2009 | Toshiba 57H82 57" Rear Projection...
Is the 55H70 a ditigtal? also is colorStream HD High Def?
it is hd ready you just need bluray player/hd cable box as long as its from a hd source or upconverting dvd player you will need component cable red blue green.let me know if you need more info.
Aug 16, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba tp50h60 convergence
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Dec 29, 2008 | Toshiba TP50H60 50" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
