Question about HP Officejet 5610 All-In-One InkJet Printer
I have a HP 5610 All In One - When I go to My computer and select scanner, it will scan the document but in the preview it comes up blank. It's a text document. I'm on my laptop that runs Windows XP
    Scholar:
  • 97 Answers
Hi Kami158,
tried to bypass the surge protector and connect it to wall outlet directly. unplug the power cord and press and hold the ON button on the printer for 10 secs. it should work.
regards,  raj_p5983
Posted on Jan 20, 2009
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Which software to scan ?
Down load the software for your windows 32 or 64 bit here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1138373&
You need the full package to use the scanner.
To scan a picture or document, follow these steps: Step one: Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
  1. Make sure that the product is connected to the computer.
  2. Turn the product on.
  3. Load the picture or document:
    • Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid.
    • ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION: Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos.
Step two: Scan the item
  1. Open HP Solution Center with one of the following methods:
    • Click Start , click All Programs , click the HP folder, and then click HP Solution Center
    • Double-click the HP Solution Center icon (c01810967.gif ) on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    c01940398.gifImportant : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Using the scan button on your printer HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. c01940398.gifImportant: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
Mar 03, 2011 | HP Officejet 4355 All-In-One InkJet...
How do i use my scanner
If you have loaded the software for the printer/scanner.
Go to your HP director Icon and start this program.
you should see your Scanner / printer listed under Select device.
You can place a document/picture in the document feeder on top.
OR you can place the document / picture directly on the glass.
(Lift the hinged lid to reveal the scanner glass)
Don't worry the document feeder uses a different scan wand.
Now document / picture in place select the Scan document or Scan picture icon from the HP director. Depending on which type of document you have placed in / on the scanner.
Scanner should warm up then scan presenting you with a preview image. From here you can decide what and where to go.
You are not limited to just the HP director.
Other applications can use the twain source to activate your scanner software. This will transfer the scan to your application.
Irfanview is a prime example. Image viewer that will let you "Acquire" and image from you scanner. Be sure to select the twain source.
Nov 10, 2009 | HP OfficeJet J4580 All-In-One Laser...
How do i scan multiple pages
Please perform the steps given below to scan multiple pages to a single PDF file.
NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto www.adobe.com and install Adobe Reader.
  1. Open HP Solution Center.
  2. Click on Settings.
  3. Click on Scan Settings.
  4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
  5. Click on OK to apply changes.
  6. Now Click on Home and click on scan Document
  7. Select Document to File under scan shortcuts.
  8. Uncheck the option Preview Scan at right bottom of the scan window.
  9. Now Click on scan to scan document.
  10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
  11. After scanning is complete Click on Finish to save the scanned document
  12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
Oct 12, 2009 | HP Officejet 6500 Wireless All-in-One...
How do I scan a document into a pdf and send by email
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr21
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not scan legal documents
hi,
alkkk-4
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
When I scan, the document comes up blank!!
Are you putting the document through the feeder? it can only scan face down on the glass...Hope this solves your problem
Jan 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
