Question about Northstar Explorer 567 Chartplotter GPS Receiver
The, back light is not working and the screen is dark but everything else works perfectly
  • Don MacGregor Jul 30, 2013
    I have the same problem and can't find a repair or replacement.
I have a proview lcd screen and it palys the tv shows in back ground but it's a dark screen like dark blue no picture. Volume and everything working but just no picture. What can i do.
Show a torch light on the screen for a distance, and if you can see the picture, the backlight is not lighting up. Check for its settings on the remote, if you have that option. Check also the settings of brightness/contrast/sharpness/color. If you still have problems, please call in a qualified service technician.
Jul 25, 2012 | Proview PA-37JK1A 37 in. LCD Television
Ipod touch backlight not on at all
yea i got the same problem... You could take it apart and replace the light and see if thats the problem or you could just send it to a shop.
Oct 18, 2009 | Apple iPod touch
My palm treo is working perfectly fine apart from
change the screen....it ll costs u around 2000 bugs!!
Sep 30, 2009 | Palm Treo 700wx Smartphone
Screen is black but computer works perfect.
When this happens it means the back light needs to be replaced. The back light is a light bulb that lights up the screen from behind the LCD display.
Sep 07, 2009 | Toshiba Satellite A135-S2276 Notebook
Dark screen on zen v plus
Was the device dropped or damanged? The most common problem is a cracked screen. The crack is on the back so you can't see it. The screen will need to be replaced.
Apr 26, 2009 | Creative Labs ZEN V Plus MP3 Player
Monitor won't light up. Only just for a second or two.
Hi
this issue is made by defective torch or lamp at the back of LCD...
Thanks!
Aug 05, 2008 | LG Flatron L1515S 15" LCD Monitor
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Jan 30, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Dark screen but just replaced it
I have a compaq laptop Hp 5000 the screen was black and I took the batterie out for a few minutes pluged the unit in and shut it back down and put the batterie back in and now works
Jan 25, 2008 | Panasonic Toughbook 48 Notebook
Northstar Explorer 567 Chartplotter GPS Receiver Logo
41 people viewed this question
Top Northstar GPS Experts
Are you a Northstar GPS Expert? Answer questions, earn points and help others
