Question about Sharp R-1500 Microwave Oven
Microwave R-1500, installed one year ago, is not cooking the food
Everything appears to be working, but, the contents are not cooked. What would have caused this and can it be easily fixed?
  • Sharp Master
  • 5,568 Answers
This model seems to be developing problems and relatively early in its service life.
Unless you have a multimeter at home (I recommend that everyone should; they cost <$20 US), there isn't much you can do other than blindly replace a fuse you should find inside the cabinet.
The back panel on most comes off pretty quick with common tools but please do not plug the unit in with no back panel; one other message mentions the presence of an arc in theirs and you really don't want to have it arc through your body.
Posted on Jan 22, 2009
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Will not heat
If everything else is working fine, the magnetron is the likely problem, "heats food and is the heart of the microwave oven" if more than five years old cheaper to replace the whole item.
Mar 02, 2012 | Whirlpool Microwave Ovens
How to set temperature in Samsung microwave. 160 c means ? watts.
They're totally non-interchangeable as they're two totally different ways of cooking.
There is no correlation at all between a temperature setting used by electric and fan ovens and the microwave power level, there's not even a rule of thumb. For microwave cooking, the fat, sugar and water content of any given food item as well as the mass and shape are what determine cooking times and microwave power levels, and not all foods can be safely microwaved as high fat/sugar content foods may catch fire.
Jul 06, 2011 | Samsung MW4699S Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R 530BS-sensor cook doesn't work. It appears to work but
In all likelihood the mangnetron has failed, You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 31, 2010 | Sharp R-530BS Microwave Oven
Does not cook food. the microwave oven appears to be working but it doesn't cook the food. Turn-table works, timer works, the light in the oven is on but my food does not cook, defrost or warmed up.
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Jan 26, 2010 | Sunbeam SBM1000 Microwave Oven
Microwave runs but food does not heat
If everything appears to work as normal but does not heat, then the magnetron will be faulty. This is the device which cooks the food, however this can be an expensive part to replace & may not be economical to fix.
Sep 23, 2009 | General Electric Microwave Oven
The microwave runs but doesn't cook the food. It made sort of vibrating noise and stopped heating. Everything else seems to be working.
HI. this is called Magnetron failure. you will need to replace this failed device. it is responsible for the heating of the contents.
Jun 07, 2009 | Maytag MMV4205 Microwave Oven
Sharp R-1500 Microwave Oven Logo
67 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
