Question about Nokia E51 Cellular Phone
Disc drive on pc not working but would like to install software..
My disc drive isn't working on my PC but I would like to install the software needed to transfer pictures,videos etc from my new Nokia E51-1 phone to the computer. is there anywhere I can download the software without having to use the installation CD?
  • 11,896 Answers
I always recommend bitpim It is a free download at bitpim.org. Works for almost any cellphone.
Posted on Jan 20, 2009
Restore disk has been lost. I need to know how to change bios to allow straight Xp to be installed
This isn't a bios setting, it's a setting that Compaq put somewhere (probably the MBR) of your OS to only allow it's restore discs.
If you want to use straight Windows XP OEM discs, just boot to the disc and you'll be able to install Windows. If that doesn't work, just format your hard drive(you'll lose everything) then boot to the XP and install that way.
Jun 11, 2011 | Compaq Computers & Internet
My wife Has a 7570 and my computer died taking all with it. It had windows vista loaded on it and PCD_WIN version 2.2 was working if you run as administrator. now the new pc has got windows 7 and have had...
Are you logged in as administrator? I'm not familiar with that particular software but most have the same sort of problems. In windows 7 you may need to 'take ownership' of the disk as administrator. Look at the 'exe" for her software in windows explorer. Right click on it and look at the security tab and see how it is set up. There and under the advance tab you will find settings including ownership, who can use.
Does the floppy work for other things? It may be that the pc isn't seeing the floppy drive properly. Try reading a different floppy and see if it also gives you the "no ID" msg. All discs have an ID so I'm not sure if this message is referring to the drive itself or to the floppy file. Look in CONTROL PANEL and make sure the PC is 'seeing' the floppy drive and showing that it is working properly.
Apr 23, 2011 | PfaFF Creative 7570
2005 Dell Inspiron 6000, I need to reload the operating software, my hard drive crashed and I have a new hard drive I am going to install. How do I go about loading in the software??
If you have your windows disc, go into your bios. Make sure your disc drive is the FIRST BOOT DEVICE. Then restart your pc and it should load from the cd.
Mar 23, 2011 | Dell Inspiron 6000 Notebook
Im having problems starting my compaq from the windows 7 install disk. I set up bios to start from dvd drive, but get a blank screen.
Windows 7 is a large operating system and would require your system to have the maximum of 1GB of memory installed. If there isn't sufficient memory for the system to load the Windows Pre Boot Environment then the install can not continue.
This system is 9-10 years old and will not run Windows 7 very well, but if you install the maximum amount of memory it should install the operating system.
You may also want to verify that the DVD drive works by trying to boot to another bootable disc such as a Windows XP installation disc or an Ultimate Boot CD that you can create yourself.
Jan 05, 2011 | Compaq Evo D500 PC Desktop
I'm trying to install the corel videostudio express 2010 and the computer won't read the disc.
Hi
you need
  • Windows® compatible DVD-ROM for installation
  • Recordable DVD drive required for creating DVDs
  • Internet connection required for online features
Do you have a working DVD DRive? if not you'll need it to install the software.
Dec 26, 2009 | E-Machines eMachines Desktop PC
On my computer it looks like my DVD drive is working but when I put in a disc I can not get it to run and even if there is a disc in the drive in Windows Explorer it says put a disk in the drive.
In other words it is not reading the disc inserted in it.
You can get a download from the internet for a DVD driver software. At the Search engine blank, type
(DVD driver software download) and at the site, choose the appropriate driver software and download it your PC. After you get the download, go back to your PC menu, and click open your downloaded driver, and get it installed. Once installed you will
now see that it is already running.
Nov 29, 2009 | Samsung SD 616E (729507925578) Internal...
Sonic Digita Mdeia Plus V7 not recognizing disc drive
You could try another program to burn discs, try ImgBurn from http://www.imgburn.com/
Sep 18, 2009 | HP dc7600 Convertible Minitower PC Desktop
Need to install liteon dvd rewriter
try cleaning the drive using lens cleaner, also if it is sata drive install proper drivers for that it works, gudday !!
Jan 20, 2009 | Ahead Software Nero 6.3 Reloaded (60096)...
Computer
1.switch on power continue del key come cmos programe you set default bios and press f10 key save settings and restart
2.first boot device hdd to save cmos solve the pro
Feb 18, 2008 | Computers & Internet
How do I read the disc on a computer?
• Windows XP Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as external DVD-RAM drive in Windows Explorer. DVD-R disc is read from the camcorder “ drive”. • Windows 98SE, ME, 2000 Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as two external drives such as a removable drive and a DVD drive in Windows Explorer. DVD-R disc is read from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Nokia E51 Cellular Phone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
