My asus laptop screen won't turn on
There is a padlock icon with the light on under the mouse pad
  • 2,385 Answers
Put the unlock code
Posted on Jan 08, 2013
byteguy
  • 2229 Answers
SOURCE: keyboard and mouse pad on my laptop. Acer 5100 vista
On an Acer, the Fn key plus F7 will turn the touchpad on and off.
Try that to see if it works.
Posted on Mar 23, 2009
  • 630 Answers
SOURCE: when i turn the think pad on i'm only getting a
It needs a password to unlock the computer. Some are set up to use a fingerprint scanner
Posted on Oct 11, 2009
  • 41 Answers
SOURCE: I have an Asus K60 Laptop.I can not figure out how
Did you try the FN key and F9...
That is what they say to disable your touchpad
You have a function key which is called Fn That key allows you to use the functions on the F series keys
So Fn then F9 should do the trick
Posted on Nov 08, 2009
Testimonial: "Awesome! THATNK YOU!"
paul7of9
  • 1189 Answers
SOURCE: Toshiba a45-s120 laptop mouse pad is frozen
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
To setup the Internet Connection: To Start, go to the “Control Panel,” you want to open the “Internet Options” window. Click on the “Connections” block, click the “Setup” button, and follow all the instruction carefully. “Important! Always click “apply, ok, and restart the computer after making changes to the computer.”
"Did this solution help?"
Posted on Feb 01, 2010
  • 340 Answers
SOURCE: how do lock my laptop mouse pad on my ASUS
you have a small button on either the left or right side of your power button. It will be orange if it is disabled. Press the button once and you should then be able to use your mouse.
Please leave rating and/or feedback if you found this helpful
Thanks!
Posted on Nov 10, 2010
Milk was spilled on the touchpad of my laptop the cursor moves but it won't click
You need to replace the touch pad or you can connect an USB mouse to your laptop and not use the touch pad.
Mar 21, 2013 | Dell Inspiron Computers & Internet
Gateway Laptop with windows 8. Mouse pointer gone and won't come back
See if the mouse pad has been accidentally turned off. This can be done via the "Function" button on your Gateway laptop. To enable your mouse clicker again on your Gateway, head on over to the "Control Menu" in Windows and double-click on the "Control Panel" icon. Click on the "Mouse" option under the "Printers and Other Hardwareicon1.png" tab. In the next menu that pops up, click on the tab listed as "Device Settings." From this menu, you should be able to locate a listing for the mouse pad on your Gateway laptop. Click on this listing. From here, you should be able to enable the mouse again. Click "OK."
  • Head over to the official Gateway site online (see Resources). The above enabling of the mouse device under "Device Settings" may not have worked. Make your way to the "Software and Drivers" area of the site.
  • Check over your Gateway manual and find your specific serial number for your machine. Enter the number into the Gateway site when prompted and check to see if any driver updates exist for your mouse on your machine. If so, click to download the update, and then double-click the file on your computericon1.png to install it. Restart your Gateway laptop to have the changes take place. Your mouse should now work.
  • Jan 26, 2013 | Gateway Ne56r34u 15.6inch Laptop Black
    I have a Sony viao laptop. And my mouse on the screen keeps trailing off the screen like its trying to run away and I can't use it as its running away it won't let me mouse the mouse where I want....
    You probably have a defective track pad. Use the function keys to turn off the track pad, and then use an external mouse, and see if the problem persists. If the problem goes away, you can try uninstalling and reinstalling the touchpad drivers from the Sony support website. If that doesn't work, you will need to replace the touchpad.
    Jan 06, 2013 | Computers & Internet
    My asus x59gl screen won't switch on, I can hear
    Try holding in the function key (very bottom left key labeled Fn) and pressing F7. If that doesn't turn the screen back on, hold it again and slowly press F8 a few times. That should turn the screen back on if it was accidentally set to a different monitor, which seems to happen randomly on laptops.
    If you can see a very faint image when its held at just the right angle, then you probably burned out the back-light.
    Keep in mind, if you bought it in the last year, it is still under manufacturer warranty.
    Feb 19, 2012 | ASUS Computers & Internet
    My mouse and think pad do not work
    There are 2 possible answers to this common issue, the first is that the aspire has a mouse lock. check your keyboard on the function buttons for a picture of a mouse with a line though it, hit function and at the same time press the mouse with the line through it and if its locked off this will turn if back on. The second answer is driver issues, if the first suggestion dont work I would go to the Acer website click on downloads and drivers and enter your model number. Then download and install your think-pad and mouse pad drivers and install.
    Sep 04, 2011 | Acer Aspire 5500 5570-2609 Laptop
    What do the lighted icons stand for at the top of the keyboard? One looks like a locked padlock with a 9 in it. What does it mean?
    That is your number lock key is turned on, which means that your 9 key keypad is ready to use. If you press the number lock key on your keyboard the light will go away but your 9 key numeric keyboard won't work until you press the number lock key again.
    Jul 29, 2011 | Computers & Internet
    My asus mouse freezes, gets stuck and wont move
    my touch pad mouse on my asus laptop will only work in safe mode, help
    Jul 13, 2010 | ASUS (W2JBY007MDVDRW) Notebook
    How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
    To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
    Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
    Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
    Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
    If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
    You can also go to link below to get help.
    http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
    Dec 30, 2009 | ASUS A6U Notebook
    Computers & Internet Logo
    174 people viewed this question
    David Payne
    David Payne
