Question about Canon PowerShot A85 Digital Camera
Getting a message "card locked"
Cannot take pictures
cannot erase images
  • Canon Master
  • 4,738 Answers
Remove the SD card from the camera. Find the tiny slide switch on the side of the card and slide it to the other "unlocked" position. Reinsert the card in the camera and try it out.
Posted on Jan 21, 2009
Get message "cannot create folder"
Format the memory card in the camera, not the computer. Also, it could be a memory card issue, do other cards cause the camera to return the same message. If yes, then it well could be the camera.
Jun 02, 2011 | Canon EOS Rebel XS 35mm SLR Camera
My camera says my memory card is locked but the button on the side is not locked how do i retrieve my pictures i have a canon powershot a480
Issue: [Memory card locked] message appears on the screen.
Solution: Change the memory card lock switch to the normal setting
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Please remove the card from the camera and ensure that the switch is not in the locked position. sdcardlocked.jpg
sdcardunlocked.jpg ---
You should be able to retrieve photos, but not writing or erasing if the switch is switched to write protect.
If it's not functioning correctly, the camera may need service at Canonusa.com.
Jun 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
All my pictures erased from the card without using the erase function . When I tried to look at my pictures, the message no images appeared.
You may have erased the photos by mistake. Try reading the memory card with your pc using a usb card reader to see if the images are possibly still there. Or you can go to this link (below) and use the free trial software to recover your photos.
http://www.datarescue.com/photorescue/v3/index.htm
Good Luck,
Eric
Jul 09, 2009 | Canon PowerShot A520 Digital Camera
Can't un-protect Images in My Canon Rebel XS
It sounds like the locking switch on the side of the SD card is in the "locked" position. Remove the card from the camera and slide the tiny switch on the card to the unlocked position. That should do it.
May 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Erase memory to recieve image messaging
Please move your Photos, contacts messages, and applications from Phone Memory to Memory Card.
then your issue would resolve. you can do this by file manager.
Feb 17, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Card Error Message
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-2 Digital Camera
Canon PowerShot A85 Digital Camera Logo
16 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
