Question about Plumbing
Greetings! My Kohler kitchen faucet model K-10416 with sprayer (16 months in use) is making noise when water is turned on in both hot and cold positions. Also, when sprayer is used water flow is not being completely shut-off thru faucet. I believe problem lies with the diverter. Does complete faucet assembly need to be removed to access the diverter valve? Schematic is not clear. Any advice would be greatly appreciated.
  • 10,865 Answers
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Posted on Jan 21, 2009
New kitchen faucet worked for 4 weeks, now the water flow is very low
Check the inside of the faucet for debris blocking the cartridge or the inlets.
Sep 29, 2014 | Kohler Kitchen Faucets. Elate Pull-Out...
Kohler a112.18.1 diverter will not spray
Generally the sprayer trigger assembly will unscrew from the hose. You can then point the hose toward the sink and turn on the
water. It should flow freely through the hose when either the hot or cold is on. Generally there is a aerator on the spray head. You can access it by unscrewing the tip of the sprayer assembly and clean out any mineral deposits. There may also be an inline type filter in the handle where it screws onto the hose that can be removed and cleaned. If this doesn't help I would guess the on-off triggering assembly is broken and you would have to replace the sprayer head.Hope this helps.
Jan 05, 2013 | Kohler Plumbing
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN Fort½ Single Control...
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
The water pressure for the hot side is less than the water pressure for the cold side. what can be done to correct this?
one of supply tubes partly blocked,turn off water supply ,disconect coupling for tubes underneath,
remove screen on faucet and blow out with air this
should remove obstruction replace in reverse and recheck pressure
Nov 01, 2009 | Kohler K-10416-BN Fort½ Single Control...
Side sprayer won't spray
THe diverter inside of the faucet is malfuncting. Remove and replace the diverter valve. It is located right under the spout assemble.
Mar 25, 2009 | Kohler K-10416-BN Fort½ Single Control...
Kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Feb 26, 2009 | Kohler K-10416-BN Fort½ Single Control...
Cannot pull out spout to replace o'ring of Kohler Faucet 10416
the pic u have up doesnt show it being a pull out u trying to fix airater?
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Plumbing Logo
430 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
