Question about Frigidaire ATF6000ES Front Load Washer
Front load washer
My front load washer will not start. The start button lights up green but nothing happens when pushed. I have check the door latch and the detergent dispenser doors to make sure they are closed properly.
  • ctf1 Aug 14, 2008
    have error code dd005 ,
  • Lilcinluwho Dec 24, 2008
    No error message. Just acts like it will start then. Door lock goes off and the rest of the lights stay on but nothing else happens.
  • 3 Answers
Yay! I just fixed mine about five minutes ago. After pulling my daughter's sock out of the pump yet once again, my washer would not start either. Sometimes I would hear what sounded like the drain pump kicking on but it would never get past just lighting up and never gave me an error message.
I checked the terminals like zeusfaber said, but it wasn't getting far enough along in the cycle to actuate the intake valves. I knew the intake side of the drain pump was clear as I'd just fixed that, so I decided to check the output side (grey hose that drains into the wall). Using my wet/dry vac I suctioned out the hose and the outlet on the back of the washer. For whatever reason, this did it. My washer works again.
Posted on Aug 19, 2008
  • 247 Answers
Easy things first: Check the water hoses are all connected, the taps are on, and that the hoses aren't kinked. Everything after that involves poking around live terminals. If you aren't happy doing this, then don't be ashamed to call someone else in. Turn the power off. Remove the top panel from the machine. On the inside of the back panel near the top, you will find the fill valves (on a few machines, there is only the one). These are the items that the fill hoses you checked a minute ago plug into. Follow the hoses inside the machine from the soap dispenser back to the valves to identify which valve is the one which washes soap into the machine at the very start of the cycle. On the top of this valve are two terminals. Attach the leads of a multimeter to these, and select an ac volts range that will stand seeing mains voltage. (If you haven't got a multimeter, suggest you buy a cheap one from the local hardware shop - it will come in handy for all sorts of things once you have it). Turn the machine on and start a wash cycle. If the meter shows mains voltage across the terminals of the valve, and yet no water is flowing into the machine, you need to replace the valve. This is a cheap part to buy, and not difficult to do yourself. IF you don't find any volts across the valve, it's worth trying the other valves to make sure you haven't got the wrong one, but then it's beginning to look like a controller problem - at which point it's worth paying someone else to come in and look at it: Once expensive parts get involved, you either need to be sure you know what's broken, or be sure you can take unneeded, but briefly installed replacement parts back. Before removing your meter leads, don't forget to turn the power off. A.
Posted on Jun 30, 2007
SOURCE:
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
No power
test the outlet with something else (lamp, voltmeter, etc) If no power, check the breaker. If you have power, try holding the button in for a few seconds, but make sure the door is latched well first. Try to start it on a different cycle.
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When I push and hold start nothing happens
can also be an issue with t door lock/latch assy, if it doeesnt recognize the door closed it wont start
Feb 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Jun 03, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer won't start
small click sounds are the result of the door trying to lock and not be able to F DL is a door latch fault, which most of the time is occuring from either a faulty connection to the door latch(wire loose), or a faulty CCC(central control unit). locatd under main top mounted to rear of cabinet. as far as the smell issue, usauallly a result of over use of detergents. you MUST use an HE detergent (HE detergent is speciffically designed for use in front loading machines) and very little of (manufacture calls for 2-3 tablespoons), theres a new product on the market WWW.AFRESH.COM to help cleanout your machine.
Mar 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 44102 won't start
when you push start button it beeps 3 times door switch is bad what model you have can make difference give me the model no
Feb 27, 2008 | Kenmore 44102 Front Load Washer
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
193 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
