Question about HP Compaq Motherboard
Hp sp 323091 001 motherboard manual
I am try to replace my Acer sk 20 computer with hp sp 323091 001.
Could anyone help me where power switch connection is?
  • Anonymous Feb 22, 2009
    "Hp sp 323091 001 motherboard Driver" problem, and notify you when a new solution is offered.
  • 70 Answers
The information that you provided is not specific to the motherboard that you have. I'm assuming that your motherboard was manufactured by Intel. You will have more luck if you can find out what company manufactured the board and also the correct model number or name of the board.
However, most motherboard have a series of pins somewhere very close to the edge of the board and, this would be the edge that sits closest to the front panel. Most motherboards that I work with have a series of pins near the edges labeled "Panel". These would be the pins that you will use to connect the power switch, power LED light, HDD LED, etc.
Usually, there are even smaller letters that, if you look closely, label each set of pins for the appropriate connectors. Take a very close look along the edges of your board to see if you can locate these pins or the word "Panel" which would be written just beneath a group of pins on the board. Some boards even go as far as to label the pins for which connector they belong (for example, there will be maybe 2 rows of pins and some connectors will only use one pin, on one row while others may use 2 pins).
Hope this helps (that is if you still have the board or this problem)...
Posted on Mar 27, 2009
    Problem Solver:
  • 17 Answers
Power switch is connected to the 2nd. pair of pins with your board installed toward the bottom or base of computer box, counting from right to left. 1st. set is for your restart button.{ not the upper row.}
Posted on Dec 18, 2009
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Driver for sm bus controller for hp pavilion zv5000
here is the link kindly dont forget to rate me fixya tell me if i have got what u wanted or u can sk me more i am here to help u
Mar 06, 2009 | Intel 845GE Motherboard
HP tx1009AU not booting up
I don't know HP's cost, of replacing this motherboard. A qualified, authorized, HP repair shop, will probably charge $300 to $400 dollars. To include the new motherboard, and labor to replace.
Too bad that you don't want to try it. A new motherboard may be $180 off of the internet.
Labor cost? 0 (But read on. This may not be advisable)
Quick search on Ebay for Pavilion tx1000 series motherboard,
Your Pavilion tx1009AU, is part of the Pavilion tx1000 Series. All the same motherboards. and the PDF Maintenance and Service Guide, (It's a Service Manual. Don't let the
-> 'Guide' fool you!)
Should the above direct link for the PDF Maintenance and Service Guide, not work for you,
here is, and the download page for it,
On this page, go down to the first manual listed ->
HP tx1000 Entertainment PC - Maintenance and Service Guide <- in blue. (Size: 3.48MB) Click on it.
You may not see anything happening. Give it 20 seconds at least, then the first page should pop up. Let it fully download before looking through it.
Tells you how to properly disassemble the laptop, and reassemble it. Gives you the part numbers, gives you the Specifications, and how to replace individual parts. Shows illustrations also.
Service Manual.
Just thought, I would pass this information on to you. Food for thought.
ONE more item!
The reason a LOT of laptops are being recalled, due to motherboard problems, stems from the DC Power Jack, and the way it's mounted to the motherboard. (Or having warranty work done)
The DC Power Jack, is that little round opening, where you plug the AC adapter, (Charger) into the laptop.
It is a small rectangular piece of plastic, that has a round metal sleeve in it, and a metal post in the middle.
This, is an example of an average DC Power Jack,
These jack's break. The middle pin can break in it's mount. Those flat metal pins you see sticking up, from the link above, go down into the motherboard. (The photo shows the jack upside down, in relation to how it sits on the motherboard)
These flat pins are soldered to the backside, of the motherboard. The solder joints can break.
For those laptops recalled due to a motherboard problem, it's due to the design of the motherboard, and how the DC Power Jack is attached.
Crude example:
Think of the laptop motherboard, as a 1 foot square. (As you can see, it isn't)
Now attach a 2 inch square to one side of this.
The 2 inch square is actually part of the motherboard. It looks like a 'Peninsula', sticking off of the main body of the motherboard.
Now attach the DC Power Jack, to this 2 inch square.
With the 'Charger' plugged into the laptop, the charger plug can get bumped. This can move the DC Power Jack enough, that the 'Peninsula' can break off, of the main body of the motherboard.
This 'Peninsula' can also break off, just due to everyday usage. Plugging the charger in, and taking it back out.
There are very flat, thin, copper strips on a motherboard, called 'Traces'. Think of them as very flat thin wires.
The traces, coming across the main body of the motherboard, to the 'Peninsula', can become stretched, and break.
This, results in No power coming from the 'Charger'. Nothing to charge the battery, nothing to keep the laptop working!
Bad motherboard design. Not the laptop manufacturers fault, (In this case HP), but the fault of the designer, that designed the motherboard.
So even if you do replace the motherboard, there's no guarantee this issue won't happen again.
Sorry this was so long and drawn out.
Jan 28, 2009 | HP 12 x 10/100Base-TX - 2 x Expansion Slot...
Replaced Motherboard now now graphics! help plz
f40b08b.gifif you are using on-board, the monitor will connect to the back panel, if its not the card will be PCI or PCI Express slots.
which on are you using?
Nov 19, 2008 | HP Pavilion dv9000z Notebook
Need a power supply to replace a Dynex DX-PS400W
Any power supply with the same pins will do. Just choose a good brand and with same rating or better higher(400 watts or more).
Sep 14, 2008 | Dynex Computers & Internet
HP dv2660 Sp. Ed.
try right click anywhere on desktop go to properties/display settings
it should show 2 monitors you may have to plug 2nd monitor in and on there should be a box to tick for 2nd monitor hope this helps
Jul 03, 2008 | HP 418446-001 - HP Special Edition L2000...
Wire it
you might try hp. i had a comp that was a p5gd1 and it was a hp model pc.
Oct 29, 2007 | ASUS P5GD1 Motherboard
HP Compaq Motherboard Logo
7,069 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
