Need capacitor number for nordyne t3ba-030k - Heating & Cooling
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Loud noise
It is probably a rotary compressor unit.
They tend to make a start up noise.
Some technicians advocate adding a booster starting device to help the compressor start more quickly, thereby reducing startup noise.
Posted on Mar 12, 2009
relaga58
  • 158 Answers
SOURCE: Need Capacitor Size
try calling technical support of the company
Posted on Jun 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: I need a replacement capasitor for Nordyne
The capacitor should have a MFD rating and a VAC rating stamped on it. That is all you need. Example 35+5 mfd. 370 volts. A 440 volt will work on all of them. The other 2 numbers must be the same.
Posted on Sep 10, 2009
Need electrical schematic for Intertherm P3RA-024K
Hi Val
check this out maybe it helps.
http://www.manualslib.com/manual/507003/Nordyne-P3ra-030k.html?page=9#manual
Dec 03, 2015 | Intertherm P3RA-042K Air Conditioner
Nordyne
Check air filter, check fan belt for proper tension if applicable. Is the coil froze up? Remove blower wheel and clean it.
Jul 14, 2014 | Intertherm P3RA-030K Air Conditioner
Nordyne T3BA-036K trips breaker on outdoor unit immediately will not stay set
Hello, sounds like a short to ground. Check all the wiring to make sure it is not touching any metal. If the wiring appears ok then the compressor windings are shorted to ground and the compressor will need to be replaced.
Jun 04, 2012 | Heating & Cooling
I have a unit with a burnt transformer the original transformer has a red blue black on one side and a black with white stripes yellow and red on the other while the replacement has a green and red on one...
Hi, I have a suggestion here that might help. Contact the manufacturer to get an exact replacement sent to you. The manufacturer is Nordyne. Nordyne makes the same unit and private labels it for other companies, like Sears, Westinghouse, Intertherm, etc. Without out the correct color codes identifying the correct secondary (24Volt ) labeling of the wires the colors are meaningless. The colors of the original transformer wires are coded for the original Air Conditioning diagram that was packaged with it. The only standard coloring found on any transformer is for the primary side. i.e. 120 Volts 60 Hz Alternating Current. Those colors are Black for Hot and White for Neutral (or return).
If you get the transformer from Nordyne or a distributed for their products, Installing the new one will be very easy.
Here is the link to Nordyne
http://www.nordyne.com/web/ContactUs.aspx
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Intertherm P3RC-030K Air Conditioner
Need wiring diagram for transformer and themostat
http://www.nordyne.com/Literature/7083400.pdf
There is a manual it has a diagram inside. http://www.nordyne.com/Literature/708340b.pdf
That's all the info i could find mentioned at all on the net, I did exhaustive searching....
May 15, 2010 | Intertherm P3RC-030K Air Conditioner
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Sep 10, 2009 | Heating & Cooling
Need Capacitor Size
Jun 04, 2009 | Intertherm P3RA-030K Air Conditioner
Loud noise
Mar 12, 2009 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
