Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Error code E000514-0000
Recently moved the Canon Image Runner 3000 and when plugging back in the above error message appeared.
  • Larry Ackley Mar 12, 2009
    Thank you for your assistance. I believe that the problem stems from the software and installed security. I have contacted the previous owners and they are sending me the codes to go in and change the setup. Once again thank you.
    Scholar:
  • 150 Answers
I researched the solution for error code E000602-0003: Your hard drive is going bad. Using the DSK CHK utility (1&9 while powering up) may fix the bad sector and get rid of the error by trying HD clear & then HD check for every sector in service mode , but more likely than not, the error will come back. You can try to upgrade the system software as well. If nothing works, you need to get the HDD replaced. This problem happens alot in these models. Hope this helps.
Posted on Mar 10, 2009
  • Kurtis Stalnaker
    Kurtis Stalnaker Mar 10, 2009
    My apologies, I appear to have researched into the wrong error code. Try the solution anyways and see if it helps at all.
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
How can I fix error code E002-0000 on my Canon image runner 2202N
Dear
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.Ok
To Enter service mode.
Press the operation panel user mode key(or additional function key), 2 key, 8 key and user mode key in this order.
To exit test mode, press the user mode key (or additional function key),to return to standby mode or make power OFF and ON.
Do not enter other than the above if you are not sure.
Thanks.
Jan 20, 2015 | Canon Office Equipment & Supplies
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Mar 12, 2008 | Canon USA - COPIERS - ImageRUNNER 2010F...
Canon Image Runner 3800
These guys have the service manual for (sorry couldn't find a free one) $7.99; http://www.tradebit.com/filedetail.php/735166 In this it details how to get into the service mode, when you should get a list of other error codes. The most likely is an E 411, which usually indicates the problem is with the document feeder tray/it's sensors, but see what you get. Please post back with what error details you get, and we can hopefully help if the service manual is not clear on the solution. The E0000000000etc message just means that there is an error considered too difficult for us consumers to deal with. Hopefully not. Hope this helps - waiting for your info :)
Jul 21, 2007 | Canon imageRUNNER 2800 All-In-One Laser...
Computers & Internet Logo
835 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
