Question about Canon FAXPHONE L80 Laser
Resetting the name of company and telephone number on fax sheet
I have a new business and need to change the name of the current business on my setting. How do I delete the current name? Also, does the name and telephone number from this business need to show up on the fax sheet?
  • 1 more comment
  • checkonhold Jan 21, 2009
    I have the same problem I have several offices and I took the machine to a new office and I can't seem to reset the information for the new location
  • Anonymous Feb 25, 2009
    I have the same problem.
  • Anonymous Mar 24, 2014
    How can I set my company name to my fax
  • 124 Answers
Welcome to FixYa! I'm the expert that chose your issue to resolve. Now let's get started. Office machines, for whatever reason, seem to be a lot more complicated than the ones you use at home. But, this should be an easy problem to fix. The process of putting in your required and company information is known as "registration" To complete your registration do the following:
  1. Press Function, then
  2. Data Registration, then
  3. Press set three (3) times. Your current settings will be displayed.
  4. Use the numeric keypad to enter the correct month, day, year and time in the following order: Year (enter only the last two digits), Time (use 24 hour time format i.e. 13:00 vs. 1:00, precede single digits with a zero (0) i.e 01:00) If you make a mistake press clear. Also, you can use the left/right arrows to move the cursor under just one digit and use the number keypad to change it.
  5. Press set two times. The display will show UNIT TELEPHONE, the TEL=
  6. Use the number keypad to enter your fax/telephone number (max 20 digits including spaces) If you want to enter spaces, press function, then space. If you make a mistake, press clear and reenter the number. You can also use the right arrow key to delete the rightmost digit and re-enter the number.
  7. Press Set twice. Unit will display UNIT NAME on 1st Press, then on the 2nd press a blank screen (not totally blank, it will have a cursor on the left and a A: on the right.
  8. Use the numeric pad (corresponding to letters printed on keys) to enter the company name (max 24 characters including spaces).
  9. Press Set (Unit will display TX TERMINAL ID)
  10. Press Stop/Reset to return to the standby mode.
Note: if you want to check that what you put in is what you want, you can print user data list. Here's how:
  1. Press function, then:
  2. Press report (unit will display ACTIVITY REPORT)
  3. Use up/down arrows to select USER DATA LIST.
  4. Press Set once, the list will be printed.
(information above from Canon)
That's about it....I imagine that in a busy office, it's hard to find time to read through a book just to do this stuff, but I have the time.
Thanks for using FixYa.com!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Posted on Jan 31, 2009
I no longer have the email account I used to sign up for Facebook on 8/11/11. How can I change the user name and password?
If you can access the Facebook account you can go to the upside down triangle at the top and click settings.
Under general settings, click edit next to email and click add another email.
Change the new email to the Primary contact and delete the first one. Click save changes. You might be asked to type your password to confirm.
For user name just click edit on the username line and change the name. Click save changes. Again it might ask for password.
For Password click the edit on the line for password. Put in your current password and your new one twice. Click save changes.
Apr 16, 2014 | Facebook Social Network
I'm using Microsoft Outlook. I have 2 messages in the outbox that have a huge attachment using power point. The attachment is too large to send. MS Outlook will not delete the two messages. It ignores...
Open the outlook, disable the lan connection or you can set the Outlook to Offline (click File > Work Offline, but don't forget to re-set it online after you are done). After you are done, right-click the file to be deleted while you press the Shift Key on the keyboard and select "Delete".
If the first step doesn't work, then move it to another folder (create a new folder) and delete the folder after you are done. (don't forget to do this in Offline mode or with disabled lan).
Again, you can try deleting the file directly from the folder. Open My computer, go to C drive as shown below (Note: User Name = Your current username on your computer):
Close the outlook and do this;
1. Windows xp:
C:\Documents and Settings\User Name\Local Settings\Application Data\Microsoft\Outlook
2. Windows Vista/7
C:\C:\Users\User Name\AppData\Local\Microsoft\Outlook
Locate the file name "outlook", must be the largest file, delete it and open your outlook. All the inbox will re-sync with your email, but your problem will be fixed.
If you need further help, let me know.
Good luck.
Sep 05, 2010 | Microsoft Office Outlook 2007: Windows
Mistakenly set up two Facebook Accounts. How do I delete one
yes it is possible to do that.all you need to do is use 2 different user name that you can remember, your name and business name.
Jul 09, 2010 | Facebook Social Network
I created the wrong User name. I want to change it to the correct user name.
Go to:
https://www.google.com/accounts/Login
Log into the account you created. You should be now at the My Account page. You'll see a section called "My products". Next to that there's a little "Edit" link.
Click on that Edit link, and you should have an option to delete the account performanently.
May 05, 2009 | Google Talk
Need to change user name and domain on Outlook email account
You cannot modify your existing ActiveSync partnership.
You must go into ActiveSync options on your phone and delete the partnership.
Note that deleting the partnership only deletes the copy on your phone. It will not delete the source mailbox on your server so don't worry.
Once that is done you can set up the new partnership with your new server.
I hope this helps.
Oct 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
Need help changing the speed dial ID numbers
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Apr 29, 2008 | Brother IntelliFax-2820 Laser Fax
How do I delete or change name on screen on my phone
from the main menu,choose more till you get to profiles,click ok and edit.you can then delete current name and or put your new name in the phone display.
Jan 06, 2008 | Motorola Mobility i870 Cellular Phone
ME AGAIN
From extension 201: Press transfer then dial 104. Press the up arrow until the station number and name you wish to change is displayed. Press the hold key to delete the current data and enter the new name with the keypad by pressing the digit 2 one time for A, press the digit 2 two times for B and so forth. The volume up and down buttons will move the cursor left and right. Press the transfer key to store the new data.
May 16, 2007 | Samsung Phone PDCSLCD12B
Canon FAXPHONE L80 Laser Logo
312 people viewed this question
old marine
old marine
