Question about Ricoh Office Equipment & Supplies
HOW to configure ricoh aficio 270 on network
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
SOURCE: how do I connect a Ricoh Aficio 350 directly to personal computer
I believe the copier only has a tcp/ip port for connection, so you will still need to run it through a router, or if the PC is not on the internet, you can connect the machine directly to the ethernet port on your pc using a 'crossover' cable
You will need to download the Vista driver from Ricoh Here:
|http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x35_45/x35_45en.htm
Posted on Mar 23, 2009
  • 22 Answers
SOURCE: Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Posted on Aug 09, 2009
prashanthcl
  • 460 Answers
SOURCE: Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
Posted on Aug 25, 2009
canontech
  • 1219 Answers
SOURCE: Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
Posted on Jan 13, 2010
How do i set up ricoh mp201on wireless network
you will need to plug in to wired network, disable dhcp and configure a ip address within your router range, then make a note of ip, reserve ip in router, removed wired connection and test on wireless.
Thats is all done.
Nov 01, 2013 | Ricoh Aficio CL1000N Printer
Aficio 270, Sc 392, error code
Good morning,
I need help, my Ricoh Aficio 1022 with this error SC-392 is an error of sensor density toner.
I've only had the unit for another and still the same, and the unit is running on another machine.
Already cleaned the connectors Unit
Please if someone can help me.
E-mail: cybercopy.udi @ hotmail.com
Jul 16, 2012 | Ricoh Aficio 1515MF All-In-One Laser...
Error 36851: No response from scanner" ricoh
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Error Code SC402 in Ricoh Aficio 270
transfer roller negative current error
Jun 25, 2010 | Ricoh Aficio 180 Laser Printer
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
How to reset pass admin RICOH aficio 1224c?
The user ID is blank. The password is the word password.
If that doesn't work, let me know.
Mar 14, 2009 | Office Equipment & Supplies
Ricoh Aficio 220 - Connection with computer
Please use the link below and scroll down to choose your Operating system, and download and install the printer driver.
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=241&ricohmodelid=5&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fhtml%5Fre%2Fmodel%2Faf22%5F27%2Faf22%5F27en%2Ehtm
Hope you have a printer controller type 270 installed on your Aficio 220, already.
It can be connected with a parallel cable or ethernet cable if you have a network card installed in the printer controller of the Aficio 220.
Jan 24, 2009 | Ricoh Aficio 220 Laser Printer
Ricoh Aficio 450
Press the diamond button to the left of the display then press number press next until you see number 6 marked configuration then press number2 tcp/ip input your ip and subnet press the #button to set the data cheers dr bob1
Mar 22, 2007 | Ricoh Aficio 450 Copier
87 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
