Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
Need a manual to print out
When i had my deck done they left a gas air compresssor behind now i m going to do my roof myself but i cant get the compressor to run it has a honda engine and yellow body the model is vt61728gaj or vt61723gaj or something like that the numbers are worn off and the ohter numbers are l1/22/03-00551. help if you can thanks i need starting instructions
I am onboard merchat vessel we have bauer copressor junior ii E3 but we cant find manual any body there to help me, please send manual my email add is rnel_had@yahoo.com
Posted on Sep 30, 2011
    President:
  • Honda Master
  • 1,388 Answers
Your compressor is most likely Campbell Hausfeld VT series with two cylinder cast iron pump. You can find lots of information at www.chpower.com. Click on the manuals button and just enter VT for a list of all manuals in that range. Do not worry about the exact model number because most all 5hp honda models are very similar as they only change a bolt here and a nut there over the years. Good luck on your roofing project. If you have other questions about your compressor just post again.
Posted on Jan 21, 2009
How many airbag sensors in a 2008 gmc acadia
1) Front End Sensor - Right--Located under the front hood in the engine compartment (2) I/P Air Bag--Located at the top right under the instrument panel (3) Roof Rail Air Bag - Right--Located under the headliner, extending from the passenger front windshield pillar to the passenger rear windshield pillar (4) Side Impact Sensor (SIS) - RF--Located under the right front door trim near the lower rear of the door frame (5) Sensing and Diagnostic Module (SDM)--Located underneath the vehicle carpet under the center console (6) Seat Belt Pretensioner - RF--Located under the trim near the bottom of the center pillar (7) Side Impact Sensor (SIS) - RR--Located under the right rear door trim near the lower rear of the door frame (8) Roof Rail Module - Right--Located behind the garnish molding on the upper rear pillar (9) Roof Rail Module - Left--Located behind garnish molding on the upper rear pillar (10) Side Impact Sensor (SIS) - LR--Located under the left rear door trim near the lower rear of the door frame (11) Seat Belt Pretensioner - LF--Located under the trim near the bottom of the center pillar (12) Side Impact Sensor (SIS) - LF--Located under the left front door trim near the lower rear of the door frame (13) Roof Rail Air Bag - Left--Located under the headliner, extending from the driver front windshield pillar to the driver rear windshield pillar (14) Steering Wheel Air Bag--Located on the steering wheel (15) Vehicle Battery--Located at the front left of the engine compartment. (16) Front End Sensor - Left--Located under the front hood in the engine compartment
Aug 12, 2015 | GMC Cars & Trucks
Have a 30 gallon craftsman 5.5 air compresssor motor runs produces a trickle of air what wrong with it?
belt slipping ??? bad pump ??? electric or gas ??? tank drain valve open ???
Aug 28, 2014 | Air Tools & Compressors
2007 hyundai elantra wont take gas
I read up on this, if you are saying you cant fill the tank, it is constantly shutting off,, it is the vapor return line,, behind you tire wheel well take everything off and clean it with air compresssor
Jan 18, 2014 | Hyundai Elantra Cars & Trucks
Peugeot 307 after boot lid has opened roof will not come out. Please note if assisted manually it works, is the operating system worked by gas, hydraulic fluid or compressed air. if so can it be refilled...
In the boot left hand side as i remember is the pump which is hydraulic behind a cover so check the oil level in this resevoir ,also use engine oil on the hinges not some silly spray as they wash out with the rain especiall that fish oil WD stuff
Jan 28, 2013 | Peugeot Cars & Trucks
Audi 2005 A4 Cabrio...roof stuck partially down. How do I fix?
This has happened to my wife's 2004 A4 Convertible 2x's. I had to read the owner's manual several times to get the job done correctly (pages in the high 70's to low 80's) ...the following is offered from memory: The handle/tool needed to accomplish the task 'manually' is located in the fuse box on the LEFT SIDE of the dashboard. A small flat blade screwdriver will enable you to pry open the fuse cover & gain access to the handle/tool. Slight twist the tool and it comes out easily. Tool is a "T" shaped handle. Once you have the handle/tool IN HAND, simply turn the RED part (only) on the handle until it 'locks' in an open position. Leaves a small space on the handle. Can't recall if you go clockwise or counterclockwise, but it will be evident. Now...move both front seats forward and tilt them to gain access to rear seat. Remove the ski boot cover in middle of the rear seat and put aside. Then, 'click' the interior boot cover panel down to gain access to a 'hole' (about size of a 50 cent piece) in the top of the boot space. This hole allows you to insert (upward) the above mentioned tool into a lock/unlock mechanism in the rear deck just forward of the trunk. The tool needs to be jiggled to go 'all the way' in...you will sense that. Once in, TURN the RED part of the handle to "LOCK" the handle into the mechanism. The tool will hang down by itself. My approach is to 'store' the roof in the open convertible position first. The front portion of the roof should be partially forward as that appears to 'release' a lever within the roof's up/down mechanism to allow you to raise the rear window portion. Thus, lift (with that friend) the rear window portion up and forward (takes some effort). The roof now has a kind of 'clamshell' appearance front & rear. The front may even flop forward but tht's OK. This step exposes the rear deck. Twist the tool to unlock the rear deck. It should click & release and a small space appears enabling you to use hands (that friend again) under it (the deck). Lift the deck up & back until the hydraulics kick in and keep the deck vertically open. Now you are ready to tackle the roof & rear window for storage under the rear deck cover. Get a friend, if possible to help with the lifting...remember, this is a "Manual" job! Once here, gently push back & lower the rear window portion of the roof into the open storage area simultaneously followed by the remainder of the roof itself. Watch fingers for possible pinching in the levers, etc., during this part of operation Hopefully you now have the roof & rear window stored in the area in front of trunk and be able to lower the rear deck to almost closed position. If so, go back to the tool and twist it to 'lock' the deck in place with roof stored. Remove tool from the ski storage area by reversing procedure above. Now comes the "Moment of Truth"! With the ignition turned on and car running, use the roof switch to bring the stored roof up and all the way to the closed position. Don't forget you must keep your finger on that switch until the operation completely finishes. Then, reverse the process to open & store the roof for a good blow dry (drive)!
May 27, 2010 | 2005 Audi A4
Sun roof will nt close cant find the rite fuse
check fuse F1.401, 30 amp in central junction box (in truck). Check your owner manual for fuse information.
Headliner must be removed to access motor.
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel water trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse
  • Circuitry
  • Accessory delay relay
  • Roof opening panel switch
  • The roof opening panel does not open or close
  • Roof opening panel adjustment.
  • Battery junction box (BJB) fuse.
  • Circuitry.
  • Roof opening panel switch.
  • Roof opening panel motor assembly.
  • Roof opening panel lifter assemblies.
  • The roof opening panel does not open or close — one direction only
  • Circuitry.
Apr 10, 2009 | 2003 Lincoln Navigator
Coleman Mach III 13,500 btu ducted roof air conditioner
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Jun 29, 2008 | Coleman Mach III Air Conditioner
1997 bmw 328 convertible top deck lid strut replacement
NEED YOUR EMAIL TO SEND SOME IMAGES.
HERE ARE THE STEPS TO FOLLOW.
REPLACING LEFT AND RIGHT GAS STRUTS FOR SOFT TOP COMPARTMENT COVER :
  • Remove soft top compartment cover.
  • Lift soft top out of soft top compartment.
  • Lift gas strut out downwards, insert in available bore and lower the linkages.
  • Remove tab washer, raise gas strut upwards and lift out.
HOPE THIS HELPS
May 29, 2008 | 1997 BMW 328
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
243 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
