My built-in microphone has stopped working
The built in microphone has stopped working and has dissapeared from my acer inspire so i cannot locate it and switch it on (if it has been disabled)
  • 1 more comment
  • omaro1996 Mar 09, 2009
    "my built-in microphone has stopped working"
  • barbiesponch May 07, 2009
    i did what you said to do, but when when i clicked the recording tab it says that no audio devices are installed
  • vernando008 May 11, 2010
    Hi,which operating system are you using?
  • 184 Answers
Click on Run and type in mmsys.cpl
Click on the Voice Tab so you can access the settings for your microphone. you can also test it first to see if its really working.
Posted on Jan 21, 2009
The sound on my acer has stoped working it says too go too control panel click printers and other hardware, and the click add hardware....this does nothing i have also clicked sounds,speech and audio devices and get compleatly lost.....please help!
Posted on Feb 24, 2010
2 Suggested Answers
vortash
  • 431 Answers
SOURCE: my built-in microphone has stopped working
Hi I am Vortash check what audio devices you have in device manager .. under sound and video controllers, select and un-install then re-boot give the unit any software it requires in the installation wizard and check if the microphone is back .
If not back up any documents and data you wish to keep and do a system restore to a point where you know the Mic worked .. hope this helps .. Regards Vortash
Posted on May 15, 2009
Does my acer aspirehave a built in microphone
Your question is "Does my acer aspirehave a built in microphone" Yes it has a built in Mic.
Apr 02, 2014 | Acer Aspire One PC Notebook
How to fix and install the built in microphone of my acer laptop
Go to "Start," "Control Panel," then double-click on "Add/remove Programs."
Click on the "Windows Setup" tab, "Multimedia," then select "Details."
Choose "Sound Recorder" from that screen, then click "OK." The Sound Recorder application will begin to run.
Step 4 will begin the microphone test.
Click "Record," which is the circle located on the right side of the user interface.
If you hardware device is functional, you should see the recording display begin to move.
5
Press "Stop," "Rewind," then "Play" to verify the audio that has been recorded.
If you are able to hear what the microphone picked up, but are having trouble hearing the microphone's input within other software, refer to the software's manual about proper configuration of the device.
If you were unable to record with your Acer microphone in Sound Recorder, continue to Step 6. 6
Scroll your mouse over to the bottom-right corner of your computer screen and then double-click on the small speaker icon.
7
Slide the microphone volume slider all the way to the top and make sure that there hasn't been a mute check-box selected.
If you are still experiencing error while recording with your Acer laptop's built-in microphone, you most likely have faulty hardware that needs to be replaced by Acer directly.
http://support.microsoft.com/kb/266677
Nov 26, 2013 | Acer Aspire 5100 Notebook
How to turn microphone on
Acer laptops feature on-board microphones for sound recording purposes within Windows.
Since an internal microphone can be a very handy tool for communication and speech-to text capabilities, working without a functional mic can severely hinder work flow for many users.
If you do not have any prior knowledge of how to repair a non-functional microphone within Windows, you may feel the need to send off your Acer laptop for repair.
There is no need, because even the most novice Acer user can do it.
The Sound Recorder application will begin to run. Step 4 will begin the microphone test.
If you were unable to record with your Acer microphone in Sound Recorder, continue to next Step.
Apr 22, 2013 | Acer Computers & Internet
How to turn microphone on acer
Cannot locate built in microphone. Skype cannotg access my sound card.
Have you checked in volume control that your mike is listed and is not muted. sorry, that is volume control/mixer.
You should also enter the sounds/ audio control section of your machine and ensure that microphone is there and is listed and ticked as an input device.
Jan 21, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
My acer e725 says the microphone is unplugged. Is the microphone built in and if so where is it located so I can plug the connector back in
It is probably located in the screen by the webcam. It would be connected to the motherboard inside your computer. Check your drivers make sure that it has them installed. If you need help with this please include the operating system your working with.
Jun 10, 2011 | Acer eMachines 520-2890 Notebook
My Acer notebook's built in microphone won't work. It's suddenly just stopped transmiting my voice, i dont see how it could of broke because its built in and i've taken care of my notebook well. It...
1. check the "mixer" properties to see if you have the "microphone" muted in the task bar.
2.You may have lost the sound card drivers also.
3. you will need to go into the "Device Manager" and see if you have drivers install properly > if not reinstall the drivers.
Mar 16, 2011 | Acer Computers & Internet
I have acer crystal eye webcam but is there already a microphone in the laptop ? or do you have to plug in a mocrophone ?
My acer has a small hole where the microphone is located, and it doesn't even have a webcam. So, I think your Acer Aspire has a built in microphone. Most laptops have had that since Windows 95 or 98 or so.
Aug 17, 2010 | Acer Aspire 3610 Notebook
Apr 03, 2009 | Acer Aspire 4520-5141 Notebook
Acer Aspire 5100,Built in microphone not found or working
maybe the computer came with a cd for it that u have to install so the built in microphone work.
Dec 21, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
805 people viewed this question
David Payne
David Payne
