Question about Biostar M7NCD ULTRA Motherboard
SATA problem during windows install
Hi! I have a Biostar M7NCD Ultra mobo, Athlon 1800+ cpu, 1.2g memory, and 80g Seagate SATA drive. I tried to install Windows on the SATA drive but i got a message saying that Window could not detect any drives. The BIOS displayed the drive during POST. It is not a new drive. It has been reformatted and partitioned using Partition Magic. I was using a 40g Maxtor IDE drive earlier and Windows could read the SATA drives 1 and 2. Also, after the failed Windows installation on the SATA drive, I tried to revert to my old 40g Maxtor IDE but the PC hangs up. I tried re-installing the OS on the IDE and the installation would be uninterrupted. However, when it got to the part wherein Windows is finalizing the set-up, it would hang. Same thing happens when I try to repair the installation. I tried installing on a 40g Excelstor IDE but the same thing happens. The PC hangs-up. I had to re-install the OS because the display was flickering on and off and then freezing. Can anyone out there help me?
  • Benjamin Que Jul 25, 2007
    Hi Guys!
    Sorry for the delay in replying.
    The solution by Psiboy did the job.
    Thanks to all of you who answered my post. It's greatly appreciated.
  • Anonymous Nov 05, 2007
    what if am using a laptop without a disket drive. how do i go ahead to install the drivers?
    Problem Solver:
  • 6 Answers
You would need to make a floppy disk with the sata drivers on them for windows to use during the installation so it can recognise the drive... assuming you don't have memory problems that is...
Posted on Jul 03, 2007
    Problem Solver:
  • 19 Answers
Try other memory or if you have 2 dimms take one out and try same to both dimms
  • 432 Answers
Could be that your hard drives are bad and/or Windows CD.
Posted on Jul 02, 2007
SOURCE:
I could not found biostar N68S3B driver for windows 7 ultimate 32-bit os
Hi
I went to the download drivers page of the BioStar website for your mobo here:
N68S3B
and the VGA driver for Vista and Windows 7 is the same one 8.15.11.8634 (the "x86" indicates 32-bit, but the driver looks to be the same for both 32 & 64 bit).
Your question about the AMD Athlon can be answered quite easily. It is a CPU and does not need any specific driver. You should however download and install the chipset drivers for the mobo.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 24, 2014 | Biostar Computers & Internet
Can i up grade to windows 7 on this board
They don't list W7 drivers
http://www.biostar-usa.com/mbdownloads.asp?model=M7NCD%20ULTRA
I think XP is the latest it will support well, partly due to the CPUs you can put in it.
Feb 04, 2014 | Biostar M7NCD ULTRA Motherboard
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Will cloned Hard drive work with new MoBo and CPU
No, it's not true, but you will need to buy Partition Magic to clone the smaller drive onto the larger one.
The new MoBo and CPU might give you more trouble though. All of the windows drivers for the old MoBo will be confused when they see all new hardware. In the olden (WinNT) days, this rarely worked. Now in the WinXP SP3/Vista days, you'll probably be just fine.
Sep 01, 2009 | Seagate Barracuda 7200.9 500 GB ATA-100...
I recently tried to install a new WD320Gb HD and windows XP won't load. I loaded it to the drive from another computer and Windows won't successfully boot up. I get a Stop: 0x0000076B (0xF7946640,...
You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Apr 26, 2009 | Biostar M7NCD Pro Motherboard
Cmos resetting
Ok so you know the bat is good cause you checked the voltage. You double checked the bios jumper making sure it is not set to clear. Looking in your manual you can go to AMD XP3200+, & you are under that. So either you have a short or your bios needs flashed because it's messed up. Could have went when the cpu died.
Jan 15, 2008 | Biostar M7NCD ULTRA Motherboard
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Windows did not detect SATA during installation
You need the manual to your motherboard to set it up in the BIOS. http://www.biostar-usa.com/docsmain.asp In the drop down menu select M7NCD ULTRA. I hope this helps. Let me know.
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Biostar M7NCD ULTRA Motherboard Logo
247 people viewed this question
Top Biostar Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
