Question about Haier XQ8M22-C PORTABLE TOP LOAD WASHER
Haier washer rwt350aw will not drain water to go to spin
4 Suggested Answers
  • 4 Answers
SOURCE: draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Posted on Jan 22, 2009
heatman101
  • 43501 Answers
SOURCE: haier XQB40-F water will not pump out
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
sonicboomele
  • 1557 Answers
SOURCE: I have a RWT350AW washer
if it is still washing then your not in real trouble in most cases the problem is to do with your water pump have hubby take the hoses of and see if any tubes are blocked if not see id=f the water pump is turning if not replace it then you should be right as water pumps often fail within months as to poor line production in some cases
Posted on Sep 29, 2010
Wont spin ,belt isn't broking
is the motor operable ?? can you hear a wirrings sound when the machine in set to run?
Oct 17, 2015 | Haier RWT350AW Washer
Haier washer model xqbm22-c, fills with water and won't wash or spin, just hums through cycle and will drain. What are possible problems?
bad water pressure switch, bad door switch? bad motor coupler and or belt. the water pressure switch does not control the spin though? so I suspect door switch or coupler
Mar 07, 2015 | Haier Washing Machines
Haier HLP21N washer will not spin or drain water.
ihe clutch is not grabing in1 needs replacing clutch assembly.
Nov 28, 2017 | Haier HLP21N Washer
Is it normal for liquid to be present in the top part of the drum?
Yes I have this type of washer and it has the water in a ring at the top of the drum to help balance it out during spin, not quite sure why but yes it should be there. The gargling sound you describe could also be the balancing hooks that attach the drum to the top of the washer which sometimes make strange noises but there fine.
Mar 10, 2013 | Haier RWT350AW Top Load Washer, White, 3.0...
I have a Haier RWT 350 washer and the tub sinks a few inches when filled with water. At least 3-4 inches! Can this be adjusted?
If you just purchased it, either have it sent back for a replacement, refund, or have the company send out a repairman to service it.
Apr 28, 2012 | Haier RWT350AW Washer
I have a RWT350AW washer we bought a year ago. It started making some noise recently (like coins or marbles were in the washer) and now the rinse cycle stopped working. When you set to rinse, it humms...
Sep 29, 2010 | Haier Washing Machines
My Haier HLP20E won't drain the water out, i think it's the pump...what say you???
CHECK THE LID SWITCH, THAT CONTROLS THE POWER TO THE MACHINE DURING THE SPIN/DRAIN CYCLE, BROKEN LID SWITCH, NO POWER TO GO INTO SPIN AN IT WON'T DRAIN
HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | Haier HLP20E Top Load Washer
Haier XQ8M22-C PORTABLE TOP LOAD WASHER Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
