Question about SanDisk (SDCZ4-000-A15) MP3 Player
My Sandisk mp3 player
It turns on but theirs always a black and white screen that appears and then it turns off what should i do?
SOURCE: my mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Posted on Dec 05, 2006
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240''s there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that''s frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately. <>
Posted on May 16, 2007
  • 626 Answers
SOURCE: trouble with my sansa
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Posted on Nov 24, 2007
  • 758 Answers
SOURCE: White Screen.
unintall the device from the computer and try to reinstall it again..if that doesnt help you you will have to get a new new device from sandisk...
Posted on Jan 04, 2008
SOURCE: SanDisk e260 mp3 player problems!
You need to unlock the device. There is a little slider button on top next to the headphone jack.
Posted on Jul 06, 2009
  • 1622 Answers
SOURCE: i was listening to music with my mp3 sandisk dansa
HI, When an mp3 player malfunctions,is usually caused by VIRUS that has affected the functions of the mp3 player..To fix the problem,you might to First rest the mp3 player and after resetting the mp3 player and it stills malfunctions, youmight need to update the firmware of the mp3player...
To reset the mp3player :
Reset via command
Push the "Power" switch downward into the "Hold" position.
Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
Push the "Power" switch upward all the way to turn it back on.
Reset via switch
Grab a steady hold around the device.
Push the "Power" upward and hold it there until it powers off.
Power the device back on by releasing the power switch and then pushing it upward again.
Force reset via power-cutting
Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
Take out the batteries from the slot and wait until the screen goes black.
Insert the batteries the same way they were mounted and attached the lid again.
Push the power switch upward to turn on the device.
Tips & Warnings
A good idea to stop Sansa devices from freezing is to always make sure that the player's firmware version is up-to-date. Download the firmware updater software from the Sansa website (see link in Resources).
To update :
Updating the firmware of your Sansa MP3 player is easy, and it will correct problems with the original software, and even add new features. Follow the instructions below to bring your device up to date. If you have any questions about the process, please consult the Sandisk website and support forums for more specific information. Links to these sites are provided at the end of this article.
things you'll need:
* A Sansa MP3 Player
* A Computer with an Internet Connection
Verify that the player is fully charged.
Verify the the player is unplugged from your computer.
Go to the Sandisk support site, linked below, select your player, and download the Sansa Firmware Updater software. Follow the instructions for installing it on your computer. If you need them, you may also download user manuals for your or watch how-to videos on updating the firmware.
Put the player in MSC mode. Go to the settings menu, select the USB submenu, and then select MSC. Some players with early firmwares do not have the USB options in the menu. If this is the case with your device, then there is another way to force it into MSC mode: Put the device in "hold" mode by sliding the hold switch until orange is visible. Next, press and hold the left (rewind) button until the screen changes. Go to the next step.
Plug your Sansa player into your computer and wait. The Firmware updater should launch automatically. Follow the prompts to update your player. Be certain not to unplug your player until the updater is finished. The software will tell you when it is safe to disconnect.
Tips & Warnings
If the above does not work for any reason, there is another way to update the firmware, by manually installing the necessary files. Consult the official support forum for specific instructions for your device. See the link below.
Be sure not to unplug your device while it is being updated. This could permanently ruin it.
Hope it helped...
Posted on May 16, 2011
0 characters
1 Points
My son has the Sansa SanDisk MP3 player Model: Fuze. When you turn it on the screen is white and there is a black spot on the right of the screen. It almost looks like a burn. Can you help me with...
Is the product still under warranty? If yes, i suggest to bring it to the store where you boughy it or to its centers to change it to a new one. Screen problem needs to be checkecd by a technicians for possible screen replacement.
Jan 12, 2011 | SanDisk Sansa m230 MP3 Player
The sansa screen stay always white can't do
try resetting it
Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 07, 2010 | SanDisk Sansa Fuze MP3 Player
How can i reset my sandisk sansa e280?
SanDisk logo appears when stated then screen goes to grey and black. All appears to be frozen.
Nov 23, 2009 | SanDisk Sansa E280 MP3 Player
My sansa mp3 player does not want to open,when I put in my PC it says its failling to install
hard reset your device. To do a hard reset hold down the power button for 30 seconds. The screen will go white then all black. When you release "sansa" will appear on screen... it will then take 30-45 seconds to reboot.
Sep 07, 2009 | SanDisk Sansa e200 MP3 Player
Fully charged but won't turn on - screen is black
Well seems I solved my own problem..
I waited about 15-20 minutes after another 15sec power button held powerdown,
crossed my fingers, and pressed the power button.
To my relief, the 'SanDisk' logo appeared and shortly after the menu popped up.
I'm just glad this isnt MY mp3.. lol (Stick with iPod, with Apple comes quality).
Nov 14, 2007 | SanDisk Sansa e270 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk (SDCZ4-000-A15) MP3 Player Logo
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
