Question about Epson Stylus Color 1160 InkJet Printer
My printer no longer feeds in Epson Premium Glossy paper S041624
I have printed on this Epson paper for some time with no problems. Now it starts to feed the paper in but not sufficiently to print on. When I press the paper button on the printer to eject the paper I hear the rollers trying to eject the paper but they don't. The printer feed works fine with plain paper and HP Premium Photo paper. I have spoken to Epson at length about this problem with no success. Does anyone have any suggestions better than buying a new printer?
  • trevorheath Jan 21, 2009
    Thanks for your suggestions.
    I tried cleaning the feed roller but it has made no difference. The paper preferences also make no difference. It is ironic that Epson's own paper does not work on their machine. Epson's final suggestion was that I buy a new Epson printer. I think I will try alternative photo papers before resorting to that. It's a great shame because I am happy with the Epson paper.
  • 97 Answers
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Posted on Jan 20, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
SX400 printer will not print on epson glossy photo paper, will not feed through rollers
Just put first not glossy paper at the top of glossy paper to start printing.
Feb 20, 2011 | Epson NX400/SX400/TX400
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Will not accept glossy paper why
The glossy paper is much harder to grab with the feed rollers, try one sheet at a time and nudge it in while it is starting to feed. It doesn't look like the printer is very old so I don't think your feed tires have any appreciable wear. Good luck, Dale
Apr 21, 2009 | Epson Stylus Photo 2100 InkJet Printer
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Quality Self-adhesive Sheets
Epson Premium Presentation Paper Matte Double-sided
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus Color 1160 InkJet Printer Logo
231 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
