Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
Computer dose not recoginse my external hard drive
I have an 160 gb toshiba external hard drive was working fine ,now my computer dose not recognise it. when i go to my computer it will show that it is there, when i double click left or right on mouse nothing happens,i get no response,but , i do here the hard drive running.i can hook it up to my espon r380 printer(using it with a pick bridge)it works that way. bugman19149@yahoo.com
  • pilg8138 Mar 18, 2009
    COMPUTER DELL 4400 DESKTOP DOES NOT RECOGNIZE THE EXTERNAL HARD DRIVE TOSHIBA160GB BUT THE DELL LAPTOP RECOGIZES IT NEED SOME ASSISTANCE HERE
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
I have a toshiba external hard drive 160 gb and I have lost the manual and can't remember how to get my files from the computer on it. I plug it into my computer, it recognizes that it is plugged in, but...
Try going to "My Computer" if you computer recognizes you hard drive it will be listed here.
Just click on it and it will open and you will see your files that have been saved on it.
Otherwise you can click the link below for the online manual for your unit.
http://sdd.toshiba.com/main.aspx?Path=StorageSolutions/USB2.0PortableExtHardDrive/USB2.0PortableExtHardDriveSupport
If link does not work copy and past to browser.
Hope this helps.
Regards,
Apr 15, 2011 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 1tb external HDD that works fine on TV not on PC anymore
Try using it on another computer. If it doesn't work the drive may be bad.
Mar 14, 2010 | Western Digital My Book Essential Edition...
EXTERNAL TOSHIBA HARD DRIVE WILL NOT FORMAT? WHAT DO i DO?
If your hard drive is recognized by your computer try opening control panel,to administrative tools,to Computer management,to storage, to disk management,by right clicking on drive you can format that drive or delete it.
Jun 28, 2009 | Toshiba 160GB USB 2.0 Portable External...
Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Feb 25, 2008 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
