Question about Maytag Atlantis MDE7400AY Electric Dryer
My atlantis MDE7600ayw is taking two cyles to dry
Clothes.  Even then some of the clothes are not dry. . . .
    Problem Solver:
  • 9 Answers
Your heating element is going out. If your dryer is still under warranty, contact the manufacturer and let them know what's going on. They should send you a replacement part, or should send a technician to fix it.
Posted on Jan 20, 2009
Clothes coming out wrinkled after drying
Is the dryer heating? If so try using dryer sheets and allow a bit more on the timer, if the clothes are still damp..If the dryer is running properly I see no other way to solve this.
Jun 07, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag atlantis MDE7600Ayw takes nearly 3 hours to dry clothes. The back silver metal grill is very hot and it still tumbles, no weird sounds. Any suggestions?
sounds like your vent is clogged or there is lint clogged around the blower wheel. Make sure to check outside where it comes out and be sure all the exaust tubing is free of lint clogs.
May 01, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis model MDE7600AYW is making scraping noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsh4w2
Jun 23, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Takes over 90 minutes to dry clothes and we use the same type washer atlantis. What is the problem or is it just to old bought in 2003.
Do a complete inspection of the exhaust system. I believe you have a clogged vent hose - dont forget the outside vent.
Nov 01, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Wet clothes after final spin cycle
There are two speed (or three) on most washer motors and what happens is that a motor speed will stop functioning--it will wash the clothes, but the high speed will not function. This also could be the controller, but more likely it is centered at the motor. It the motor is functioning, it coulfd be in the transmission of the machine--which may be the problenm since you heard a loud noise. I am not familiar with your machine, there could be an electronic switch for the transmission to go into high speed as well that has gone bad. I wish I had more direct knowledge of your machine.
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Feb 28, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
May 19, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
266 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
