Miele novotronic w828 noisy bearing
Noisy bearing
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Miele Novotronic W828 Water Control System Front Load Washer
Hello Ellen, welcome to fixya. I would begin by removing the rear panel and checking the belt and insure the basket pulley isn't loose as well. If the belt is in tack ( not broke ) but has come off that sometimes is caused by a loose or bent pulley, hence the suggestion to check the pulley. If the belt is broke, it may simply be a matter of normal "wear & tear" and just time to replace it. Hope that helps point you in the right direction. Please take a moment and rate this info according to it's helpfulness or let me know if I can assist you further. Thanks for visiting "fixya" today and good luck. Macmarkus :)
Posted on Jun 03, 2010
  • 40 Answers
SOURCE: How to change miele novotronic
Turn the machine off and unplug it! There are 3 10mm bolts around the door that need to be removed, the soap dispensing drawer needs to be taken out and you have 3 torx20 screws (one on the left and 2 on the right) that have to be removed. The bottom left corner of the machine there is a small door that you open, remove the hose that's clipped inside it, there is a small tab on the lower left, release the tab, pull open the door. To take out the seal you have to loosen the 8mm bolt band clamp, and pull the seal off. Fit the new seal on until you hear it pop. and reverse the order.
Hope it works for you.
Posted on Feb 28, 2011
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
There is a bad mould build up on the inside seal of my Miele Novotronic W828, Can you help, the smell is terrible, flows through the house.
You need to wipe the seal down with vinegar. Mold needs water to grow. Have you looked at the bottom of the dishwasher after a cycle to see if you have standing water? While you are looking clean the filter.
Nov 02, 2013 | Miele Dishwashers
Flashing rinse light miele novotronic w828
Broken electronic as a result of worn shock absorbers. See www.youfixit.eu
Aug 27, 2012 | Miele Novotronic Premier 500 Front Load...
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
How to change miele novotronic W828 door seal?
Feb 28, 2011 | Miele W526 Front Load Washer
Jun 03, 2010 | Miele 300 Front Load Washer
Mielepremier novo. No power though plug fuse OK. Door won't open.
I had the same problem with a Miele W828. I removed and reinserted what I think was a condensor where the power cord is attached, after which it was OK. I assumed that it was loose but might have just been lucky in bumping something else back in place when I tipped it onto its side.
Mar 28, 2009 | Miele Novotronic Premier 500 Front Load...
Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
May 24, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
