Asus x501u Ethernet port not working properly only had the laptop 2 months so not sure what could be wrong with it
2 Suggested Answers
herwinpradan
  • 177 Answers
SOURCE: asus x501u
you can upgrade it with a DDR3 memory and max 4GB of memory
since it's a laptop,i suggest you to take it to notebook center for installing the memory,because laptops hardware is pretty fragile,but there are many guides on the internet if you want install the memory by yourself
Posted on Aug 28, 2012
How many memory slots does an asus X501U have?
The X501A has ONE slot and can take up to 4Gb.of
204-pin SODIMM DDR3 PC3-12800 1600MHz
Oct 17, 2014 | ASUS Computers & Internet
Why is my screen blank when I turn on my computer?
Before starting your laptop up... try to remove and clean the connector surface of the memory card/s with pencil eraser,soft cloth or tissue paper. Then insert the memory card/s back properly. check the unit if it is booting up nicely.
Aug 18, 2014 | ASUS Laptop AMD E1 1200 Processor X501U...
X501u turn it comes on to the bios wright away carnt get out of it
from my experience, 3 out of 5 its a keyboard problem. the other is a hardware malfunction.
Jan 26, 2014 | ASUS Laptop AMD E1 1200 Processor X501U...
Asus x501u memory upgrade
Might have to replace instead of adding. Quick search indicated it can go up to 4GB.
Aug 27, 2012 | ASUS Computers & Internet
I re-imaged the unit & it says the network card is working properly in device mgr. But it wont go online when i connect a cable. It stays on "Network Cable Unplugged". The LED on the connection on the...
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
Sep 29, 2009 | HP Pavilion N5415 Notebook
Wireless switch on my pc is on but cant connect Work with ethernet cable plugged in.Are there any settings?
Things to try:
1. Plug in the ethernet cable then restart the laptop.
2. Right click on your local area connection and make sure its enabled
3. Make sure your wireless adapter is disabled.
4. Check if you need a static ip address on your work network. and if so have them assign you an ip address for your laptop.
5 Test your computers ethernet port on another wired network to make sure that it is good.
6. Get a usb to ethernet adapter for your laptop if your ethernet port is bad on your laptop.
Sep 11, 2009 | Intel Computers & Internet
Ethernet Wont detect under XP even with latest drivers
If you already checked the cables then perhaps its the nic card, Check if its properly installed under device manager and make sure there is no question mark or exclamation point. Reinstall the driver if needed.
Aug 26, 2008 | Toshiba Satellite 2410-S203 Notebook
USB ports setting
Do you have them setup according to your motherboard diagram?
Apr 30, 2008 | ASUS P4S800D-X Motherboard
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
