Question about Dell PowerEdge T410 Server
E2110 multibit error on Dimm A2 reseat dimm - Dell PowerEdge T410 Server
2 Suggested Answers
  • 96 Answers
SOURCE: BOOT FAIL: PCF8584: I2C ERROR
According to the message you received on the screen there's might be something wrong with your RAM module(s). Take a look inside and see if everything's alright with RAM. Replace it to another slot if there are empty.
Download and use a program like MemTest to see if RAM is properly working.
If you have another computer which is compatible with your RAM, try it inserting then in to PC and see if everyhting's alright.
If nothing helps, then purchase a new RAM module
Posted on Jan 30, 2009
E2111 SBE LOG DISABLE -DIMM 3
Hi
Two most likely causes for this error are
First: the memory module, DIMM3 has worked its way loose and needs to be reseated firmly in its slot with both catches firmly engaged.
Second: The memory module DIMM 3 has become faulty and needs to replaced.
If reseating the DIMM doesn't work try swapping slots with a module of the same size in a different slot and see if the fault follows the module or goes away. If the fault follows the module, eg to DIMM 1, then it is most likely that the module is faulty.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 30, 2014 | Dell OptiPlex Computers & Internet
Hpcolorlaserjet 2700 showing 79error
Check the grounding of your power oulets. If there is equilizing current trough the ground shield of the interconnecting cable, the information can be transferred with errors. Then the printer cannot process it and gives the 79 error. But HP recommends:
A critical hardware error has occurred.
  1. Turn the printer off and then on.
  2. Reseat the firmware DIMM.
  3. Reseat the formatter.
  4. Replace the firmware DIMM.
  5. Replace the formatter.
Oct 09, 2014 | Cell Phones
62.0 error
62.XX error
There is a problem with the printer's memory. The x value refers to the location of the problem:
0 = Internal memory
1 to 3 = DIMM slots 1, 2, or 3
Recommended Action
Reseat or replace the specified
DIMM
It might also be the formatter but start with reseating the DIMMs
Dec 04, 2013 | HP LaserJet 8150dn Printer
How do i fix my hp laserjet 4000n error code 53.11.03
Dear Percy
Thanks for posting. Try the below steps to solve your printer problem
1. Turn the printer off, and reseat or replace the specified DIMM.
2. Try the DIMM in another slot.
3. Replace the DIMM that caused the error.
regards
Saleem
May 17, 2012 | HP LaserJet 4000n Printer
Compaq dc7600 help
Hi
Sounds like your beep codes are being caused by a Pre-video memory error, where your onboard video chip uses a portion of your ram.
first, best to unplug the power cord
try reseating the DIMM's in the memory slots on the motherboard, and then turn on your computer.
if no go.
remove all but one DIMM and try booting. if your computer boots now, then the DIMM that isnt in your computer is most likely faulty.
i would also inspect the DIMM sockets with the DIMM's out to see if there is any damage to them. have seen a number of cracked sockets and this can be a problem, with even the slightest bump causing a DIMM to move, and causing this type of error.
If you still get the error, if you reply back in here, can help you further.
hope this helps
Feb 16, 2010 | HP Compaq dc7600 PC Desktop
49 error turn off then on problem:
pls perform these steps
Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM in the lower
slot J1).
Remove the printer EIO card.
3 turn the printer on
4 If the error does not persist, install each
DIMM and EIO device one at a time.
Turn the printer off and then on again
after installing each device.
5 Replace DIMMs and EIO devices as
necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware dimm
& calibrate the printer
ur problem will be resolve
Dec 18, 2009 | HP LaserJet 2700n Printer
E2111 SBE LOG Disable DIMM
The E2111 should also indicate a number after the DIMM, this is the bank of the DIMM it believes to be bad. Depending on your support contract situation, and ability to bring down the machine, reseating the module after cleaning it a bit with some good old 'canned air' may do the trick. Otherwise a module replacement is in order which is typically covered by DELL if you are still under coverage.
Jun 29, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Hp laserjet 1200 series
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
Adding More Memory
Reset the BIOS using the motherboard jumper before booting into Windows.
Jul 23, 2008 | ASUS P4S800D-X (610839122325) Motherboard
Extra memory
My manual for P4P800-VM says :-
Mode Dimm A1 DimmA2 DIMM b1 dIMM b2
single ch 1 populated
2 populated
3 populated
4 populated
Dual ch 1 populated populated
2 populated populated
3 populated popuated populated populated
for dual channel 3 configuration you may
install identical dimms in all four sockets or
identical in A1 and B1 [blue ]
and identical in dimm A2 and dimm B2 [black sockets ].
Probably same as yours
Good luck
64bvt
Jun 18, 2008 | ASUS P4P800-MX Motherboard
Dell PowerEdge T410 Server Logo
2,965 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
