Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
My wep is 10 digits. Needs to be ASCII! Help
I can't get my Eee PC on my wireless router because the wep is 10 digits. It says it has to be typed in ASCII format. Which is 5 digits.
  • 2,460 Answers
A 64-bit WEP key is 10 HEXIDECIMAL digits (0-9 A-F). In my own system I just use 1011121314. I don't have to think. You can use something like 123456FACE or something else cute, but the end result is still 10 HEX characters.
Try logging in again using 10 ASCII characters or check the router for the WEP key again, or even add a second key just for your eee PC.
Carl
Posted on Jan 20, 2009
IM HAVING PROBLEM SETTING UP WIRELESS ROUTER TO MY COMPUTER
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you can remove the network cable from the back of your pc.10. restart your pc then search for new wireless networks then connect.11. now enter the WPA passcode or WEP passcode that you have created on the instruction #8. then you are good to go.
Dec 26, 2011 | Zoom 45010003F Wireless N Desktop Router...
Tip
How to setup wireless settings for D-link Airplus G DI-524 Wireless Router
1) Open web browser (firefox or internet explorer)
2) on the address bar, type 192.168.0.1
3) on the pop up screen named as "connect to 192.168.0.1", type admin in the User name field and leave the Password field blank and then click OK
4) click Wireless Tab on the left side and click Home Tab in the middle screen
5) Put a dot mark on enabled under WEP to turn ON wireless security
6) Under WEP encryption, try to set it to 64-bit which will allo you to type 10 charaters(combination of alpha and numeric characters)
7) under KEY type, set it to ASCII
8) try to use Key1
9) dont forgert to click Apply so that settings will take effect.
on Feb 15, 2010 | Computers & Internet
I have my network open and i wish to put a password on it.. how do i do that?
Hi.
First, you need to access your router.
To do this, open a browser, and in the address bar type in: 192.168.1.1
This takes you inside the router's web access program.
From here you can change settings like security.
here as all the instructions for changing it.
  1. Type the following text in the user name and password fields: "admin".
  2. Go to the Basic Settings menu option tab on the top navigation bar and wait for the menu to appear.
  3. Click the Wireless Security menu option in the drop down menu.
  4. Click to select Enable Wireless Security.
  5. Click to select either WEP or WPA in the Network Authentication list.
If WEP is selected
  1. Select hexadecimal or ASCII characters as the Key Format. You can use either as a string of hexadecimal digits (characters 0 through 9 and A through F ) or as ASCII characters (any key on the keyboard).
  2. Select an encryption level from the Key Length list.
  3. Enter four different keys in the Key1, Key2, Key3, and Key4 fields to store on your router. For 40(64)-bit encryption, enter a 5-character (or 10 hexadecimal digits) WEP key. For 104(128)-bit encryption, enter a 13-character (or 26 hexadecimal digits) WEP key.
  4. Select only one key out of the four keys as the Default Key for encryption.
  5. Click the NEXT button, and then click Save and Restart to apply the changes.
  6. Set up WEP encryption on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients' on-line help systems, for information on how to set up WEP encryption.
If WPA is selected
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9 and A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key "rotates" or changes.
  4. WPA Encryption allows you to select one of two possible encryption methods-TKIP and AES. Choose one that your wireless clients support.
  6. Set up the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients' on-line help system, for information on how to setup WPA.
I know it looks like a lot of information, but really it's not.
Just follow these steps and you're security eill be set up in no time, and then you can rest your fears about someone else using your network without your permission.
NOTE:
NEVER store the password in your computer, because in the event of an infection, that information could be stolen.
Write whatever your new password is down, and keep it safe somewhere. That way, if someone does want to use your network, they will have to ask you for it, and you will have it for them.
I hope this gets you going the way you want!
Feb 08, 2011 | Dell Wireless 2350 Router
I just purchased a Netgear N300 wireless usb adapter. After installing the netgear software it ask for the WEP code off of the Centurylink provided Zyxel 660hw. The problem is the WEP code on the bottom of...
WEP code will be 10 digits only...you need to type all the 10 digits together (without any spaces)... Try disabling netgear utility and use your default windows utility...It is not the problem with netgear....
Aug 07, 2010 | Zyxel Prestige 600WH Wireless Router...
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Can't setup to virgin braodband
You mean ascii and hexadecimal.
  • Hard wire your router to your PC with an ethernet cable
  • Open your web browser, go to website http://192.168.0.1
  • Input username/password both are "admin" (without the quotes)
  • choose "wireless settings" (third tab from left)
  • go to "security" (fourth tab from left)
  • Choose WEP (if the first box on this page already says WEP you may skip this step)
  • choose 64-bit
  • type random 10 digit code into key 1 (eg. 38-38-2D-E3-B0)
  • Save settings (bottom of page)
  • write code down somewhere or make it easy to remember
  • disconnect your ethernet cable from router, try to connect to wireless network, enter code (from above) and it will connect.
Jun 26, 2009 | Sitecom (WL -004) Wireless Adapter
I can't get the ASCII working for WEP security key on my dir-625 router.
WEP is ASCII, but it's 10 HEX digits for 64 bit. In the simple example, I use 1011121314 for my key. It keeps the casual user out of the sytsem and I don't have to remember much. Good code for my cul-de-sac.
Usitn the characters A-F, you could actually spell something out that you remember like FACE123456.
Carl
Mar 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless is not secure
Step 1 Log into the Router
A device which forwards packets between networks. The forwarding decision is based on network layer information and routing tables, often constructed by routing protocols.'); return false">Router
by entering it’s IP address into a browser. The default IP address is http://192.168.1.1. At the login, enter your username (admin) and password (admin).
Step 2 Click on “Wireless” on the left hand side then click on “WEP” at the top of the page.
tew-432brp_f_1.jpg Step 3 Enter in the desired encryption values then click “Apply”.
Examples:
Authentication type:WEP WEP
Type: Open
System Mode: Hex WEP
Key: 64-bit Key 1: 0000000000
Note: For WEP you can choose ASCII or HEX modes.
64bit ASCII = 5 digit ASCII key.
64bit HEX = 10 digit HEX key. (Can only use letters A~F and numbers)
128bit ASCII = 13 digit ASCII key.
128bit HEX = 26 digit HEX key. (Can only use letters A~F and numbers)
You can also choose WPA
Wi-Fi Protected Access (WPA) is becoming the wireless security standard. It is a higher level of security than WEP that combines encryption and authentication to create an unbreakable level of protection. For small office and home users the WPA preshared key (WPA-PSK) is the easiest set up and does not involve a Certificate Authority Server, which is recommended for small and large business customers. Once the preshared key is set-up on each network device, every packet sent over the wireless network will receive its own encryption key under the Temporal Key Integrity Protocol (TKIP). A key benefit to WPA is that it is backward compatible with WEP-only devices. For those users looking to ensure those who share keys are who they claim to be a Certificate Authority Server or RADIUS Server can be added. This requires a more complicated set-up and is not recommended for smaller networks. Also, one thing to note is that WPA adds to the packet size, typical transmissions will take longer.'); return false">WPA
-PSK. The key must be between 8~64 digits.
Authentication type: WPA
-PSK
Passphrase: omg laserbeams pew pew pew
Confirm passphrase: omg laserbeams pew pew pew
Jan 05, 2009 | Trendware TEW-432BRP 54Mbps Wireless...
I have an eee pc 900.i am with aliceadsl.it recognises alice but i cant connect.if i try to put in wep key either nothing happens or it says not enough digits. i cannot find how to the security key in and...
1. dissconnect the dsl modem wait 10 seconds
2. plug the power back up to the DSL modem
Thats the universal protical for reset.
3. inter your router setup page
This can be done by typing 192.168.1.1 in your browser address bar and pressing enter
consult your router documentation or website for specific numbers.
if your router wants a password or user name the default password may be "password"
( no user name required )
4. enable the wireless network in the router configuration pages.
5. enjoy having complete control of your router configuration.
Thank you for choosing FixYa!
Az.
Sep 18, 2008 | Computers & Internet
Secure network
- access your web user interface by typing http://my.router (or the default address http://192.168.2.1) on the address bar of your web browser
- click on Basic Settings
- click on Wireless Security
- click on the Enable Wireless Security checkbox
- select either WEP or WPA in the Network Authentication list (Note: make sure that your wireless computers can support wpa if you're planning to use wpa. wpa is more secured than wep)
if you're going to setup wep, follow the steps below:
- select hexadecimal or ASCII characters as the Key Format, you can use either as a string of hexadecimal digits (character 0 ~ 9 and A ~F ) or as ASCII characters (any key on the keyboard)
- then select your desired encryption level from the Key Length list. it could be either 40(64)-bit or 104(128)-bit key length.
- enter four different keys in the Key1, Key2, Key3, and Key4 fields to store on your router.for 40(64)-bit encryption, enter a 5-character (or 10 hexadecimal digits).for 104(128)-bit encryption, enter a 13-character (or 26 hexadecimal digits) WEP key (note: you'll just need to enter the characters that you've setup on Key1 for all the wireless computers that you have
- click NEXT, then Save and Restart to apply the changes
if you're planning to enable wpa, follow the steps below:
- enter your pre-shared key. this key must match the key that is used by each wireless client computer associated to your router.
- choose a key format. this can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard)
- WPA Group Rekey Interval specifies how often the key "rotates" or changes
- WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports
then connect your wireless computers to your wireless signal using the correct wireless security (network key)
hope this'll help you.
Jun 08, 2008 | Dell TrueMobile 2300 Wireless Router...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
243 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
