Question about Dryers
My mde7600ayw is taking two cycles to dry and sometimes that doesnt work.  what is wrong?
  • Dryers Master
  • 8,220 Answers
Easy fix! You have a bad blower wheel. The plastic blower wheel gets loose on the motor shaft and there is no way to tell untill you remove the front and inspect it. Also a ball of lint builds in the front of it when it goes out.
Posted on Jan 20, 2009
My Maytag atlantis MDE7600Ayw takes nearly 3 hours to dry clothes. The back silver metal grill is very hot and it still tumbles, no weird sounds. Any suggestions?
sounds like your vent is clogged or there is lint clogged around the blower wheel. Make sure to check outside where it comes out and be sure all the exaust tubing is free of lint clogs.
May 01, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Heat is not always coming on in dryer. Roper dryer from Lowes
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Apr 26, 2010 | Roper REX4634KQ Electric Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
My atlantis MDE7600ayw is taking two cyles to dry
Your heating element is going out. If your dryer is still under warranty, contact the manufacturer and let them know what's going on. They should send you a replacement part, or should send a technician to fix it.
Jan 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer isnt drying on frist cycle
This is most likely an element problem. it is best that a tech replace it but if you feel comfortable take it out and to your local repair shop. match it up and reinstall it.
good luck
Jason
Jan 19, 2009 | Roper Dryers
Taking to long to dry
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Dec 08, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
90 people viewed this question
Top Dryers Experts
