Is it 220v single phase
SOURCE: When I turn on my steam unit it powers up takes
go to the following link
http://www.manatron.net/Pdf's/Sussman/residential.pdf
the manual may help you with yur problem.
it is hard to say what is wrong without looking the actual unit.
SOURCE: Mr. Steam won't start up
Hi my name is Mike I am with Mr. Steam Tech Support please give me a call at 800-767-8326 ext 1280 or email at [email protected] and I will happy to help you with your unit
SOURCE: Mr. Steam CU-750 not working
CU - 750 - the unit fills, element energizes, it doesn't make steam.
The element was installed two weeks ago. If the element went bad so soon, what could have caused this?
SOURCE: error code Prr
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
SOURCE: Mr. Steam steamer is inppoerable
I just got this problem too, any solutions or a link to the manual?
