Question about Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
Nail stuck and bent in nail gun - Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
3 Suggested Answers
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
  • 384 Answers
SOURCE: My nail gun will shoot one nail then stop. Any
I had the same problem with my Stanley stape gun. Had to replace all the seals and piston. Works find now! Check-out internet ...search for a rebuild kit for your model of gun. Get the complete rebuilding kit ....take about 1/2 hour to rebuild.
Posted on Jun 12, 2009
Why are my finish nail guns releasing only a small puff of air and that's all?
Indicates stuck driver. Remove the head and check for stuck driver or jam due to derbies or broken/bent parts.
May 18, 2015 | Air Tools & Compressors
The gun will fire the first time but will jam when i try to fire it again.
Assuming that the gun will not jam with nails removed and the driver returns to top of cylinder when fired without nails. If the driver is bent the nailer will jam without nails. Jamming is usualy caused by bent driver, driver tip worn (not square), or wrong nails. If the driver is not bent and the tip is square, suspect wrong nails. Easy test. Place a strip of nails on outside of rails with the nail heads aligned with top of rail. Move the strip of nails toward the nose if gun. With the heads aligned with the top of the rail, the first nail should align with the path of the driver. If the first nail does not align with the path of the driver and the head is angled slightly away from the path of the driver, the driver may strike the shaft of the first nail pushing the nails back into the rails. If the head of the first nail is forward with the nail shaft angled back away, the nail will flip causing jam. The first nail should align with the path of the driver to prevent jam. It is difficult to find perfectly made nails that align correctly. But certainly check the nails with test mentioned above with every new box for accuracy. You might find that you will need to change brands to get a good fit. Good luck.
Nov 06, 2012 | Air Tools & Compressors
Nail gun wont drive nails..just makes a weak popping sound
Popping sound indicates stuck driver or worn trigger valve. Remove the head and pull out the driver. The driver should fit snugly in the cylinder. Replace the piston oring if the drrver drops down the cylinder under its own weight. Check for bent or broken driver and replace as needed. Lube cylinder with silicone paste lube or nail gun oil. Check that the headvalve is not stuck in the head and lube as needed. Replace head and test. If no joy, replace the trigger valve. Good luck.
Aug 21, 2011 | Stanley Bostitch Stick Framing Nailer...
Problem: Nail jam due to improper degree of nails Question: How do I take apart the nail gun so as to get the jammed nails out?
Try removing stuck nails without taking apart gun. Remove remaining nails from rails. Use long piece of allen wrench or similar hard steel and grind the end to allow for jamed nail (I use a broken driver blade ground slightly thinner to allow for stuck nail). Use heavy brass or copper hammer to push driver up to top of cylinder. If after a couple of heavy blows the driver does not move, remove the head of the gun and pull out the cylinder and place the body of the gun on plywood. This will protect the head from damage. Good luck
Jul 13, 2011 | Stanley Bostitch Nail Gun
8 penny nails are stuck in gun. How do you get them out?
If the nails are stuck in the rails, remove the rails and fish them out. If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
May 03, 2010 | Dewalt D51844 Framing Nailer
The gun will fire staples, nails do not set.
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
When I load the nails, they do not sly to the front of the gun therefore it does not work. Powershot pro 9100 staples/nail gun, eaglalex@aol.com
Could be couple problems, the magazine, nail carrier is slightly bent or wrong nails is there enough spring pressure on the pusher? and maybe some foreign object in the magazine. Take a look and let me know if you need more assistance
Sep 11, 2009 | Powershot Tool Company Tools & Hardware -...
May 20, 2009 | Stanley Bostitch BT200K
Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2 Logo
43 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
