Question about Epson Stylus CX4600 All-In-One InkJet Printer
Magenta and yellow won't work, cleaned nozzles 8 times and still the magenta and yellow don't show up. How can I unclog the yellow and magenta. My cartridges are Epson cartridges.
Cleaned the nozzles now 8 times and still no yellow or magenta
J PENGUIN
  • 12 Answers
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Posted on Dec 31, 2007
SOURCE: Epson Dx6050 not printing in magenta & yellow?
Have you tried taking them out and putting them back in? Sometimes they don't 'seat' properly. Are they Epson carts?
Posted on Sep 18, 2008
SOURCE: Epson R1800 printer won't recognize new ink cartridge
ughhhh I'm having the same problem... STUPID MAGENTA
Posted on Oct 13, 2008
kd6rhd56
  • 400 Answers
SOURCE: Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Posted on Jul 12, 2009
  • 30 Answers
SOURCE: MISSING MAGENTA NOZZLE..
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-8
Posted on Sep 04, 2009
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
Magenta won't print at all on test page. Tried normal cleaning cycle several times to no avail. Also tried "power purge" cleaning cycle twice also with no success. Help!
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 20, 2013 | Brother MFC 6490CW InkJet Printer
Even with new inks, magenta and yellow won't print
The ink you replaced costs as much as a new printer that comes with ink. Get a new one.
Aug 27, 2012 | Epson Stylus 2200 InkJet Photo Printer
Printer acts like it is printing but it spits out blank paper. Ink supply shows up as good. What could it be?
If the printer has not been used in some time ink may have dried in the print head. Unfortunately Epson have a non-removable head, so it can not be cleaned without a kit available for purchase. If you have installed new cartridges make sure any air tags have been removed. these are usually on the top of compatible cartridges or on the bottom of Epson brand cartridges.
The kits are available online, Search for Epson head Cleaning Kits and you will find one.
I hope this helps
Regards GM
Apr 21, 2011 | Epson Stylus C88 InkJet Photo Printer
Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magicis ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Sep 11, 2009 | Office Equipment & Supplies
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
