Question about Sanyo Dp55441 TV
Sanyo dp55441 no picture but has sound thru medicom hd box
Could our Dish remote control be causing our picture size problems? The ends of our picture are cut off. We've used the TV remote to change the size but all of those options are still too big.
the ends of the picture on most non hd will be cut off because they are made for the old tvs which don't have the same aspect ratio as the theatre screen shaped flatscreens.
Sep 01, 2015 | Sanyo DP55441 55 in. LCD HDTV
Scren went blank. We have sound but no picture .what do we neen to do to get pictute?
How is your TV receiving video? Are all cables connected? With RCA (the red, yellow, white ended cables) the yellow is the video, the white and red are left and right stereo sound. Ensure that all cables are connected into the correct spot on the back of the TV and that you are on the right input (Video 1, AV1, etc).
Mar 15, 2015 | Sanyo DP55441 55" LCD TV 1920x1080, 120...
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
Jan 03, 2015 | Samsung HW-D450 Sound Bar
Manuals schematics
What does blinking out mean? You should be more specific. This can be that the picture is cutting out to snowy noise, meaning that the tuner board has issues or over heating, for example.
Jul 10, 2014 | Sanyo Dp55441 TV
Sanyo dp55441 - wont come out of sleep mode. every hour a msg comes up tv will turn off in 1 min. how do i turn this off? pls and thank you
hi go into the menu on the tv scroll down to picture setting look for sleep timer select off
regards
shaun
Jan 31, 2014 | Sanyo Televison & Video
Remove base plate of dp55441
To know more about this, you have to download the repair manual to this set. Try for it. If you wish to get some information, check the site linked here. It has disassemble procedure to many popular brand TVs, with illustrations. Pull up older posts. Disassemble procedure will have details you want.
Nov 27, 2013 | Sanyo Dp55441 TV
Why is my TV picture dim
Hello David
It sounds that the back light inverter board, and back light CCFL lamps to your TV need to be checked. It will be best to contact any service technician, because to check its back light CCFL lamps, you must disassemble the display panel, a very skilled work indeed. If you are sound in electronics, you can check it. If you wish to know more http://electronicshelponline.blogspot.com/ check this link. It has details. Pull up older posts there by its left side bar, or see it in 'Timeslide' option.
Jun 18, 2013 | Sanyo Dp55441 TV
How do I connect a Toshisba soundbar?
Your sound bar should have some sort of HDMI IN and HDMI OUT. This means that there are at least one place to plug a HDMI cable into the bar from either your dish or bluray player and then you take another HDMI cable and plug it into the port labeled HDMI OUT and this will plug into your TV either in HDMI1, HDMI2, or HDMI3 and then it will provide sound for the device. Unfortunately you didn't not list the item so I can not look it up to see if it can accept multiple devices so if it only has two HDMI ports then it can only support one device and you will have to manually change out devices through the HDMI IN port. Essentially the soundbar is just a pass though and takes the sound and sends the picture to the tv.
Jun 03, 2013 | Sanyo Dp55441 TV
Sanyo 46" 1080.must you use hdmi cable to get best picture?
Yes. HDMI cables are the best for sound and picture quality with an hd signal at this time than anything else. A lot of people can't see much of a difference using HDMI rather than s-video, component / video, or rf cables but there is a slight difference. You will have to have an hd signal or source such as an hd sattelite receiver, an hd cable box, bluray, etc to benefit fully w/ an hdmi cable.
Aug 03, 2010 | Sanyo Televison & Video
The picture on my HD tv is pictulating - I have a sky HD box. Some of the channels are perfect, some have a small bit of interference in the picture and some are unwatchable with a lot of crackling in the...
It is not the tv,but weak signal strength thru thru your satellite or cable box. Please call them to rectify this and you will not need service on the tv itself
Jun 15, 2010 | Televison & Video
Sanyo Dp55441 TV Logo
71 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
