Question about Logitech Z-5500 Computer Speakers
Digital Sound Control Center
The Control center on my 5500 keeps dropping after a few minutes..Sometimes it powers up and immediately goes off..Or with some jiggling will stay on a minute or 2. Then I hear crackling or static from the speakers and it switches off at the control center, I called Logitech and they will not sell me a new controller. They will only sell me a complete new system... It's only a little over twoyears old..WHat a waste. The speakers are perfect, the S/W appears to be fine. I dont know if the short is there or in the controller. I suspect the latter. Logitech dont want to know. Is there anywhere I can send it for diagnosis? Wonder whats causing this....
  • IZZY413 Nov 10, 2007
    The Control center on my 5500 keeps dropping after a few minutes..Sometimes it powers up and immediately goes off..Or with some jiggling will stay on a minute or 2. Then I hear crackling or static from the speakers and afterwards I get no sound at all!! I press the test but on my remote and all the speakers and sub/w are functioning properly. I'll turn the power off and on and sometimes i'll get sound maybe for a minute and then the sound cuts off completely. PLEASE ANY IDEAS??????????????????/
I had a similar problem with my z5500. I would get a loud pop and my controller would shut off or sometimes it would not shut off but would not work. I contacted Logitech support through thier web site and after about a week of dialog and attempted fixes they sent me a whole new speaker system and all I had to send them was my old controller. So now I am also looking for a controller to make my old set complete again. It was pretty great getting a whole brand new system at no charge
Posted on Nov 11, 2008
Maybe change the fuse.
Posted on Aug 29, 2007
Suggest a problem with internal power connections open up the unit a check.
Posted on Jul 02, 2007
SOURCE:
When I turn on my Samsung LNT4669 it seems to make a clicking noise a few times, and goes on and off, on and off, a number of times (sometimes as long as 20 seconds) before finally turning on.
replace bad caps in power supply near connector going to main board (where the inputs are) or just replace power supply board p/n: bn44-00166c
Dec 16, 2010 | Samsung LNT4669 TV
The camera was dropped and the lens is extended and will not retrack. There is no control with the power switch
Try sending the camera to Panasonic Repair Center for immediate repair. They can help you repair the unit since it was hit badly during the fall.
Thank you.
Aug 01, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
No sound no light @ logitech z-5500
search for service center on net near you can not repair it your self or jast call them
Oct 24, 2009 | Logitech Z-5500 Computer Speakers
Center channel goes muffled after a while of use.
It is likely that something overheating is causing the problem, but nothing should be overheating. Cleaning won't hurt and may help but it is likely to require repair of the faulty component, perhaps a failing capacitor or amplifier.
Dec 29, 2008 | Marantz SR-19 Receiver
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Nov 17, 2008 | Logitech Z-5500 Computer Speakers
Center speaker channel
This sounds like a bad connection inside the receiver. A 5 minute fix with a soldering iron and about 30 minutes to get to it.
If you can solder you should be able to fix this yourself.
Dan
May 23, 2008 | Yamaha Digital Sound Projector YSP-800S -...
Problem with optical & coaxial
Good Morning Pulpy
First things first,
1) did you have a digital Sound Card?
2) did you install all drivers on Sound Card? and set to Digital Audio?
3) your speakers are analog? or Digital Input?
do a speaker test and see if center spk. work..again.
good Luck
Nov 17, 2007 | Logitech Z-5500 Computer Speakers
Popping sounds
Hi! depending on the brans speaker, dunno, sometimes the heat , or eletric changes , damage the board for the sub, this came of pop sound suddenly, you have to replace the Subwofer. in any case. the satelite speakers you can keep it.
I presumme is a Sound Blaster set?
some models of sound blaster speakers, like 5600 and others, have some problems with pop sound on the sub. keep and eye on them.
good luck
Nov 14, 2007 | Logitech Z-560 Computer Speakers
Logitech 5500 Surround Sound controller
It 's not the fuse!!!! THAT fuse is only for SUB !!! if that fuse was the problem he wont have power at all.THE problem is with control center .I fix my control center changing 2 diodes ,but a friend of mine have exactly the same problem comming from some transistors with is located above that 2 diodes D700,D701(so he says) --- surf check google and you ll see a lot of customers with exactly same porblem AND THIS PROBLEM I THINK IS SOME DESIGN ERRORS THAT AREN'T FIX BY LOGITECH BEFORE SELLING THIS SYSTEM!!!!!!!!!
Jun 30, 2007 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
356 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
