Power supply doesn't seem to supply power to Gateway labtop
Everything was working fine, until the cord got snagged on my foot but i caught it before it pulled the computer. Then after that even when the power supply was plugged in, the computer still ran off of battery power until it ran out. I don't think it's a problem with the laptop rather, the cord and/or power supply itself.
    Scholar:
  • 108 Answers
It may have broken the small wires inside the cord, in which case you'll have to replace the adapter. You can pick one up at Office Depot. They have universal ones with different tips for all brands. Optionally, if your adapter has removable cords just change out the cord. You can find them at Fry's electronics or any online store like newegg.com, tigerdirect.com or zipzoomfly.com
Posted on Jan 20, 2009
    President:
  • 846 Answers
Well its likely that you could have damaged the power cord. If one of the internal wires got yanked when your foot caught the cord it could have lost it's connection. Try going to an electronics store and asking if they have any universal adapters, look on the back and see if your laptop model is supported. Try it and see if it works, if not return the cord and the problem will be with the female plug in the back of the laptop. Like you said its probably not the laptop
Hope this helps, please comment back if you have any further questions or information about the problem. Feel free to leave positive feedback if this helps, thanks for stopping by at Fixya!
My Toro mower won't start. The cord will not allow me to pull it out all the way. It seems to be caught on something.
Disassemble the starting mechanism and remove the snag in the line that is preventing you from pulling cord all the way out. Till you do that, you will be pounding salt.
Nov 01, 2015 | Toro Garden
Gateway GT4010 desktop pc powers up but NO VIDEO. I cleaned a massive amount of dust from the system and have checked every connection, cleared the cmos/bios, tried to power up with just the power supply...
Dust can be a massive cause of problems on a motherboard as it acts like a blanket causing components to overheat and sometimes conducts small amounts of electricity. Many boards on this condition are basically fried and need replacing. You could try a 24 pin power supply but i doubt that will make any difference as you have done everything to restore it.
Regards.
Apr 19, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
My gateway 503gr will not power on when you press the power button has power to mother board every thing is plugged in there is a green light on the power supply and the mother board and the power switch...
This could have a bad power supply (in this case I would try a new one just in case).
All other things being normal, I would guess a bad motherboard.
The best thing to do is disconnect everything but the CPU and memory and try to start it.
If it starts, then start connecting stuff until it doesn't start--this will tell you what is bad.
Apr 13, 2011 | Gateway 503GR PC Desktop
My gateway desktop PRB 510S, if I turn it off and unplug it or electricity goes off, the computer wont start back again. Wont do anything. No lights no fan, nothing. Then 5 to 10 minutes after I turn it on...
Try connecting a different power supply to it. If the same situation repeats, then it's an internal (motherboard) problem. If the problems go away, then the power supply needs to be replaced.
6 years... I'm surprised the PSU even lasted that long! The power supply is the cheapest part of the PC and usually one of the first parts to fail. Don't worry, a replacement power supply is not too expensive. Good luck!
Dec 02, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Gateway 830GM power
Could be power supply, unplug every thing from the board, remove all drives, cards everything but the mem. turn it on, if you get some beeps, add your Hard drive. The power supply may not have the guts it take to run all the peripherals it used to, this test will tell you if its the board or power supply.
Jul 15, 2009 | Gateway 830GM PC Desktop
Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Jun 02, 2009 | Gateway MT6840 Notebook
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
