Question about Nikon D80 Digital Camera with 18-135mm Lens
Flash doesn't work
I dropped my camera and now my auto flash doesn't work and there is a delay in the picture taking when I push the shutter release button. Pictures sometimes come out blurry especially if the subjects on in motion. I had dropped my camera and the shutter release button doesn't want to work all the time.
Don't drop a D80. wrap the fabric clipped onto the camera (say for hanging around your neck, which is a bad idea because of heat.) around your wrist two to three times, EVERY time you use it.
Posted on Jan 21, 2009
Shutting off flash
Yes, but not in the Auto mode, where the camera decides whether or not it needs the flash. Switch to the P mode, which works like Auto except you have control over the flash, exposure, and other factors. See pages 26 and 42 of this manual.
Apr 12, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
How do i get my camera from having a time delay between flash and actual picture
This is a common situation with compact point&shoot cameras. Between the time you press the shutter release button and it takes a picture, it has a lot to do. It has to find the subject and focus on it, meter the light and set the exposure, perhaps set the white balance, and other things. Larger, more powerful (and more expensive) DSLRs have more powerful processors and additional hardware to speed up the process.
One way you can reduce this shutter lag is to press the shutter release button halfway to focus and meter before you need the picture. Keep the shutter button pressed halfway until the action hits its peak, then press it the rest of the way.
Jun 29, 2012 | Polaroid Cameras
Jun 29, 2012 | Polaroid i531 Digital Camera
The flash of my sx30 doesn't work, when i open the flash it was detected that the flash is open but the the problem is when i'm going to shoot even i press my shutter it doesn't take any...
hion flash defuser unit up position, it doesn't allow to take picture. This means technically flash circuit is continuously sending charging signal causes blocking shutter release.( but not all of model, it is depend on model of camera.). Like this case, it is obvious that either a fuse brown or charge controlling pcb defective. I recommend you send to your local repair shop or canonUSA. They would charge around $45 to165 depend on what they really want to charge.
Jun 05, 2011 | Canon PowerShot SX30 IS Digital Camera
On the easyshare m575 what does the self timer/burst feature do?
Self-timer
(10-second delay) it will have a 10 on it
Time to get yourself into the picture. Place camera on a tripod or flat surface.
Self-timer
(2-second delay) it will have a 2 on it
Allows for a steady, auto-shutter release on a tripod.
Self-timer
(2 pictures) it has a 2X on it
Capture 2 shots (one picture taken after 10 seconds and another picture taken 8 seconds later).
First Burst
Flash forced off.it has like 2 folders in front of the camera
Camera takes up to 8 pictures (2 per second) while the Shutter button is held. The first 8 are saved. (Capture an expected event e.g., baseball swing)
Last Burst
Flash forced off. it has 2 folders behind the camera
Camera takes up to 30 pictures (2 per second up to 15 seconds) while the Shutter button is held. When the shutter button is released, only the last 8 pictures are saved. (Capture an event when the precise timing is uncertain e.g., a child blowing out birthday candles.)
Mar 03, 2011 | Kodak Cameras
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
There is a delay from when I push the button to take a pic and the actual pic of a second maybe. How to get pic in the moment?
The delay is caused by the flash charging. Put the camera in Program mode (P on your dial). This is similar to Auto, but you can turn off the flash. Press the button with the lightning bolt by it until you see the same icon but with a slash through it in your LCD screen.
Now keep in mind taking pictures this way will often result in blurry pictures because you're overiding both the Autofocus (by pushing all the way down on the shutter instead of first half way), and the flash (you may need to keep the camera extra steady in low light situations).
Nov 15, 2009 | Canon PowerShot A75 Digital Camera
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Jun 02, 2009 | Nikon D300 Body Only Digital Camera
Flash doesn't work
check the flash settings.. it just might be on 'Slow or Rear' flash mode. good luck!
Nov 08, 2008 | Nikon D40x Digital Camera
Delay in taking pictures
Shutter release button has two positions. Auto focus function activate first when u press butten halfway(u can see a focus indicator icon with beep sound).Now if u press it some more, camera will take snap at earliest .So pl confirm the subject to be focused by keeping the button half way pressed then press it some more at the right moment.Also cancel the red eye reduction function when u r using flash because it creates more delay .
Nov 26, 2007 | Canon PowerShot A540 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
143 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
