Question about GE Dishwashers
GE motor 5K41LT80S wiring diagram
I want to use a washer motor for a grinder machine. How to hook wires?
  • 11,896 Answers
Assuming that this is your motor. You only need the black and red wires. Just put a switch in between the black wire and the other ground wire you are using
Posted on Jan 20, 2009
Wiring diagram of pressure switch
All Ge washers should have a wiring diagram inside the control panel on the left side if standing in front of the machine. Hopefully it wasn't removed by someone.
Apr 01, 2015 | GE WPRB8050D Top Load Washer
Motor wiring diagram
A suppression capacitor has 2 wires and can be have red and black wire pair, and a motor have 2 wires from the electric field to the carbonbrushes and 2 other wires from the magnetfield goes to the switch and on the same wires can be connected a parallell suppresion capacitor connected bud in most cases its not needed in practice.
The other 2 wires have to come from the powercable on the switch the most grinders to find in shops are class 2 angle grinders with double insulation, But If this is an bench grinder there must be a class 1 cable used with 3 wires to earthing a metal point on the housing. look always for the 2 square symbol its class 2 and cable has 2 wires otherwise 3 .
Aug 14, 2014 | Grinders
It hums but won't turn. are there brushes? what is the black canister hooked to wiring going to motor? aloha, chip
Hi Chip , have you tried !!carefully!! turning the grinding wheels whilst the grinder is powered up and humming and does this start the machine , if it does your motor start capacitor ( a cylinder/tube with 2 wires or connectors on it ) will be deffective or the leads might have became detached from it , a replacement capacitor is quite cheap but you must replace it with the exact one ( a motor start/run capacitor of the correct Mfd or uF rating typically 30 uF/Mfd and at the correct voltage 110/220V )
if this dosent fix your problem most likely your motor start windings in the motor field coils are burnt out and the grinder is uneconomical to repair .
hope this helps .
Jan 22, 2010 | Delta Shopmaster 8" Bench Grinder
GE washer Model S3600DOWN will not turn off water. overflows WHY?
suspect water level control they call it a pressure switch
there is a quarter inch line that runs from tub to pressure switch that line can sometimes plug requiring line be removed from pressure switch and cleared
http://www.repairclinic.com/Washing-Machine-Top-Load-GE-Style-Appliance-Diagram
this web page shows a breakdown of commom top load ge washing machine level control is located in top panel
before opening top panel unplug washer from wall
if clearing line does not work level control will probably need to be replaced suggest take picture or draw out
where three wires are hooked before removing part or
change 1 wire at a time to avoid mixing up wiring
Dec 12, 2009 | GE Washing Machines
WICH WIRES DO I HOOK UP TO RUN MOTOR USING 2 SPEED 7 WIRES RE BLU YEW BL PUR WH ORANGE
Have a appliance repairman come because, may cause electric fire or damage to you or property. the repairman should have wiring diagram.Some washers have a ele disgram on inside of machine panel. Hope this may help. Becareful with electric.
Jun 01, 2009 | Washing Machines
Is it possible to take a Whirlpool 3363736 and make a grinder?
I see bench grinders for about ten or twenty dollars at the flea markets all the time. They also have the $$ grinding wheels on them.
May 16, 2009 | Washing Machines
Older sears bench grinder wont run 1/3 hp model 397 19581
Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
Mar 04, 2009 | Grinders
GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Oct 03, 2008 | Washing Machines
Dishwashers Logo
398 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
