Question about Brother DCP-7020 All-In-One Laser Printer
Envelopes - Ghost image of the address to the right of the addr
All 4 printers in the office started doing this within the last 2 weeks.
  • Anonymous Feb 17, 2009
    Having the same problem...any solutions out there??
  • 215 Answers
To janemays, since it happened on all 4 at same time, i'm wondering if you possibly are using a different type or brand of envelopes. that would be first thing i'd look at.
razors
Posted on Feb 18, 2009
Ghost Image of the address appears when I print envelopes. Our agency also has the same brand, different model doing the same thing.
Ghosting is caused by a worn drum unit. The printer drum is used to transfer the image to the paper and is coated with Teflon, when the coating is worn the toner sticks to it a bit and you get the ghost images. The part number you need to get for the replacement is DR350, they are available online or at Office Depot, Staples, Etc.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | Brother MFC-7820N Laser Printer
How do i print addres on envelopes on mx310
Yes through MS Word.
Go to the file menu select page setup select the paper tab and then from the drop down menu select paper size and select envelope. If you have multiple options for envelope like envelope9, envelope10, envelope11 etc. select the envelop size that you want. The paper size of the document will change to the specified envelope size and then you can print the document normally using any printer.
Jun 22, 2010 | Canon PIXMA MX310 All-In-One Printer
How to print envelopes?
use the hp software ..and use the envelopes templates in the setup of the page ..or ...just open Microsoft office word ..and select the mailings and in the left side will be the envelopes template ..(office 2007)
Jun 03, 2010 | HP DeskJet 940c InkJet Printer
I have a officejet pro 8500. I have a problem printing envelopes
Check two areas
1.. It could be the software your using to print the envelops.
2...It could be the printer driver.
Go on HP's site, and check and see if there has been any updated printer driver, or patch file. Hope this helps.
Dec 21, 2017 | HP Office Equipment & Supplies
Envelopes will not print with address in centre of
You have to make the adjustment to the position with the software you are using. What are you using?
Nov 03, 2009 | HP LaserJet 5L Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    LEXMARK X1240 WON'T PRINT ENVELOPES
    I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
    Jun 01, 2009 | Office Equipment & Supplies
    Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
    Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
    Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
    Ghost Image
    mark165,
    Are they both about the same age? Also have you recently added a device that is sitting near the monitors such a an external hard drive, printer, new speakers or power cord or cable next to or against the monitor cable? I sounds like EMI to me, shield the cable or plug of the offending devices into another outlet away from the monitors to test that theory, or having them on a separate surge protector should eliminate the noise you are reporting. Some go as far as adding UPS with line filtering (or conditioning) for the devices - you see it with home theater setups when the TV, computer, games and stereo are all plugged in the same outlets on the same home circuit.
    randy320sgi
    Jan 12, 2009 | Computers & Internet
    Envelopes
    CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER IF YOUR DARING.)
    Jan 29, 2008 | Brother HL-2040 Laser Printer
    Brother DCP-7020 All-In-One Laser Printer Logo
    125 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
