Question about Linksys WRT160N Wireless Router
Loss of internet connection to desktop with WRT 160 N
I too am having issues with my desktop internet connection thru the router (linksys wrt 160 n). It is connected with a network cable and will occassionally not conect to the internet. After a few minutes, or after rebooting, it works fine. Wireless connections are fine. is there a setting that is blocking the connection temporarily? It acts as if it times out then after a couple minutes it's back on. Whe plugged directly to the cable modem, the desktop works fine. I have tried 3 calls to Linksys and changed a couple setting but no better. HELP!
  • thdarragh Jan 21, 2009
    Thanks. I'll get that info out in the morning.
  • sprender1 Jan 22, 2009
    Similar problem here:  desktop is fine if plugged into modem; if plugged into router, I can ping/admin the router but can't web out.  Laptop would usually connect but drop connections.  Then I noticed on the laptop I could ping out (I wrote a script to ping the router, then the router's outside address, then the gateway (ISP), then the three ISP DNS servers).  Browsers would start connecting to where I wanted usually during the gateway or DNS pings.  So I hard-coded the three DNS servers on the protocol, and removed IPv6 drivers (running Vista 64-bit).  Now the laptop connects every time, although occasionally I have to "kick it" by running the ping script only once (when I first open the browser).  Other non-connections get resolved with a browser refresh.  This is annoying but doable.  The desktop however is still more no-connect than connect through any of the four ports.  Tried other cables, etc.  Also tried the "laptop-fix" (hardcoding DNS servers, disabling IPv6; this machine is Vista 32-bit) but that's not working.  I really USED to like Linksys...
  • 258 Answers
If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
1. connect to modem with an ethernet cable, without the router
2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
Posted on Jan 20, 2009
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
No connection display on ethernet connections
DD-WRT firmware is very specialized. Can you ask on a site that provides support for DD-WRT ? Can you log in to the console ?
Sep 09, 2012 | Linksys E3000 Wireless Router
Client Mode or 2nd Wireless Router with new Subnet Mask?
The original firmware does not have this option, but you can get a custom firmware at http://www.dd-wrt.com/
DD-WRT is not supported by linksys, so a little caution there as this could ruin your router if it is not installed properly. Fortuately they have plenty of documentation on installation and troubleshooting if needed.
Also found this on how to setup Client Mode through DD-WRT - http://www.dd-wrt.com/wiki/index.php/Client_Mode_Wireless
May 20, 2012 | Linksys WRT54G Wireless-G Broadband Router...
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Linksys wrt 120n connected but can't browse
Check your computer's browser settings, make sure it's getting valid IP address, try pinging a website and check your IP settings under network connections.
Disable any third party firewall software you have installed.
Hope this helps!
Jul 20, 2010 | Linksys WRT120N Router
Wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Router causing loss of internet service
i think your router has some issue .i thkn may be u need to change your router.
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Router to use as relay.
Linksys WRT54GL with DD-WRT firmware. Now, DD-WRT will void the warranty, but it has been incredible for my uses when configuring WDS. A the WRT54GS has also been said to be an excellent router, but I cannot say.
Dec 22, 2007 | D-Link AirPlus DI-524 Wireless Router
Linksys WRT160N Wireless Router  Logo
511 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
