Question about Blitzz Technology BWA711 (B3WL000900) Wireless Router
What is the IP to get in to reconfigure a Blitzz router?
    Scholar:
  • 108 Answers
Click start> run> type cmd press enter> type ipconfig /all (make sure you put space between ipconfig and the /) look for default gateway ( that's the IP of your router).
Posted on Jan 20, 2009
I am unable to access my blitzz bwp611 router. I have tried 192.168.1.254 and 192.168.0.1 to no avail. How can I gain access to this router?
The router should be accessible from the Default Gateway IP Address of your network. Examples I have found are like this:
http://portforward.com/english/routers/port_forwarding/Blitzz/BWA611/Command_and_Conquer_Red_Alert_Counterstrike.htm
you can check you default gateway by opening a command window (Start CMD, right click CMD on the Menu for Vista/7, Start, run cmd for XP) on the command line type IPCONFIG
This will give you your IP address, Subnet Mask and Default Gateway IP address. Type the Default Gateway IP address in to you address line of the browser, you should get a sign in prompt. Unless you changed the default settings, the username and password should be left blank. That should give you access.
Jul 10, 2011 | Blitzz Technology (BWP712) 802.11g/b...
I forgot my pasword for wireless router. i used reset button on blitzz, got new IP and typed new IP into internet address line and got an error message.
admin is both the default username and password for this device. When you used the reset button, you erased your credentials and it went back to the default settings.
Jun 23, 2011 | Blitzz Technology BWA711 (B3WL000900)...
How do i password or firewall my Blitzz BWA 721 router?
you want to secure wireless network.
is there any other computer connected to the router with the ethernet cable?
If not then you will need to connect the computer to router with the cable.
check the ip address on the computer.open the set up of router. you will find the option to make it secured.
Click Here for step by step instructions
Nov 11, 2009 | Blitzz Technology (BWA611) Router
Blitzz wifi router default userID and password?
The default is admin and admin...
If that doesn't work, the reset button will clear the stored login information and reset your router to factory default.
Make sure you hold that button for about 15-20 seconds before you release it. After you did this, you can access your router again via the default IP address2.gif of 192.168.1.1
The default username and password for your Blitzz router are both "admin".
Don't forget that all your personal settings will be erased as well (wireless security2.gif, port forwarding etc.
Nov 08, 2009 | Blitzz Technology (BWA611) Router
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
Apr 30, 2009 | Blitzz Technology (BWA611) Router
Reconfigure
Access the configuration page of the router (Example 192.168.1.1) under the settings look for the MTU to set to 1364.
Mar 10, 2009 | Blitzz Technology BWA711 Router...
How to reconfigure router
you may need to reset to restore the defaults.
the the default username: admin and password: admin
Jan 16, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Limited or no connectivity with my blitzz 802.11b wireless card
my computer did the samething so i took it to a computer repair shop and they reconfiguered the network connections and now it works fine, but bring your router with you so they can reconfigure that too. it cost my 25 bucks and i think that it was worth it. It saved me alot of headache
Nov 20, 2008 | Blitzz Technology (BWP612) 802.11b...
Reconfigure router
I seriously can't stand those motorola routers specially since they have to reboot themselves after every change.
Unplug the power from the router, hold the reset button in and plug the power back. Keep holding the reset button for 30 seconds. That should restore it back to factory settings. Plug one machine to the router and try to access the admin console. if memory serves me correctly, the user name is admin and password is motorola.
Jun 14, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz router
get into the routers settings and check that DHCP is enabled to allocate ip addresses automatically and that your computers network cards tcp/ip properties are set to obtain ip address automatically. When you connected the modem directly your ip address has probably changed.
Apr 09, 2007 | Blitzz Technology (BWA611) Router
Blitzz Technology BWA711 (B3WL000900) Wireless Router Logo
90 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
